Currently running my Mag off an Orion 600d and the output is absolutely unbelievable...which only makes me want to see how much further it will go. If i purchase a Directed 1100d will it be a good/noticeable difference? Do you recommend Directed Audio? Any input appreciated
directed makes solid amps. it should also be noticably louder as well. if i were you id look into the d2400 the look nicer if you ask me. also what box you have yours in?
It's in a ~2.7 sealed box I built for the first time...nothin complex but i did manage to put a double baffle on =P. I'll have pics up soon as I get the carpet on. The reason i ask about the 1100d is I found one for 100 and figured that would be a pretty decent price.
your almost doubling the power so you should get around a 3db gain. also if you port your box then you could get another 3db. in theory it could be 66% louder.
