2 batteries vs a cap
Username: Crouchere
Post Number: 11
Is it slum to have 2 batteries instead of one cap. I don't have a cap, but two batteries, i put an extra battery in the trunk. I put it in a box with vents and sealed it; i ran tubes out the box and out vents in the trunk so the corrision and acid wont destroy my equipment. Should i still get a cap?
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 508
caps are basically useless, get a HO alternator and you'll be fine.
Username: Adddisorder
West palm, Florida
Post Number: 2975
what batterys and what size alt are you running and what amps fisrt off
Username: Carguy
Post Number: 5918
Croucher, why why why would you put vents in your trunk?? Haven't you heard of sealed yellowtop batteries? No acid to spill and gases to worry about.
Look for a similar topic in amps and accessories. Your question was already answered. I'm sure you'll find it interesting.
