EPG on Viewsat post
Username: Ke5aqn
Shawnee, OK USA
Post Number: 676
I have a viewsat I have never had over 2 hours of EPG on dish or bev. I have understand it is supost to be a 7 day? I am going now to see if the receiver is set to only get 2 hours.....ok here is one setting...option's EPG hours----set to 24 I just hit "receive guide" we will see what that does..
Username: Tapeman
Post Number: 459
There is an option to set to 24 hours
and an option#7 to actually receive guide called receive guide
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 926
mine is never ending....goes days and days
Username: Ke5aqn
Shawnee, OK USA
Post Number: 678
ok I was on a DN sat wehen I hit receive guide....it got 24 hours of DN. I changed to bev hit receiver guide it gor the same dn no bev guide.....so what to do now?
Username: Mc_sunny
Post Number: 1068
Make sure u have ur time setting right
If it dosn't work for you...You need to load a good sat file and then the latest bin
Post Number: 927
ya something not rite,Jay....should work better than that
Username: Ke5aqn
Shawnee, OK USA
Post Number: 679
thanks Mc Sunny I have time right and latest bin......satscanner whats your settings to get the guide past the 24 hour?
Post Number: 928
time mode auto ...-5:00hhrs
Post Number: 929
works on bev and dn
Username: Ke5aqn
Shawnee, OK USA
Post Number: 680
isn't that setting for your time zone? I have mine at -600 for central time.
Post Number: 933
-5:00 eastern for me and no other settings to do it always there after the bin flash.maybe try reflashing Jay.
Username: Prfrmnj
Post Number: 1785
Let me know if you guys get it to work. The most I've gotten out of it is 24 hours. I have loaded new SatInfo files, but have not been able to get it done! Or as Larry the Cable Guy would say "Get 'er done!"
Post Number: 935
I had a problem when i first got it ,only epg on bev and echo 3 t7no echo 7/810 and everyone said I was retarded...lol how about you Jay ?...lol
Username: Prfrmnj
Post Number: 1786
I have EPG but only for 24 hours. Actually the EPG is really good, but I just read you guys had 7 day EPG? I'm curious as to how you did that...
Post Number: 938
it just does that on its own.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 681
Glad to see PRFRMNJ has the same thing...it was the same with the pansat as well. I worked on this problem for hours and hours on the pansat and never got it working eather so.....and yes I was based last time for asking about it
On bev it has always only had 2 hour and I have to go to a channel on it to get it all the time.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 682
Well thanks we tried mabee someday it will work better
Post Number: 950
btw...mine is ultra ,dont know about epg on extreme.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 683
Mine is a platinum
Just thought of this before the last bin (the one that mapped the locals ) Their was more option for more than 24 hours. Does your have a option for more than 24 hours?
Username: Mc_sunny
Post Number: 1069
Jay, The last time i checked up to 5 days EPG and it was still going and i have Viewsat Ultra, also You need sat 119 in the mix to get the 7 days.
- Try this, let me know if it work for you
Electronic Program Guide) Populating Info..
More EPG (Electronic Program Guide) Populating Info...
Still see a little confusion about getting the GUIDE to fill.
Getting questions like "why does Dish 119 info fill up, but Dish 110 doesn't"?
To get a 7-Day Guide on Dish 110 and 119, press the SAT button on your remote.
Highlight "Dish Package" and press "OK".
If you don't have both 110 and 119, then select the Dish Sat that you do have.
Exit out of the menu and Press the Guide button.
Press the "FIND" button while in the guide and leave it sit on that channel for a few minutes.
The longer it sits, the more EPG will fill up, 7-Days max.
To get a 3-Day Guide on BEV, press the SAT button on your remote.
Highlight "BEV package"
If you don't have both both 82 and 91, then select the BEV Sat that you do have.
The longer it sits, the more EPG will fill up, 2-3 Days max.
The EPG can NOT fill up if you've selected "All SAT" from the SAT LIST button.
Also, it can not fill the BEV EPG while watching Dish and vice-versa...that is just NOT possible, because the EPG fills GUIDE data ONLY from the provider you are watching.
-epg population
ever wonder what channels propugate epg better then others? heres a list of some popular sats their tps and channels.
tranponders and channels for egp
satellite 61.5w
12632 R
tp 29
channells 607/615/620/778
satellite 82w
12224 R
tp 1
channells 260/337/574/578/654/716/
718/719
satellite 91.3w
12268 L
tp 4
channells
158/211/212/507/521/559/
615/621/627
satellite 105w
11740 H
tp 2
channells
7000/9385/9386/9387/9388/
9390/9391/9392
satellite 110w
12326 L
tp 8
channells
503/506/507/510/516/521/523/524/100
satellite 118.8w
11840 R
tp 7
channells
799/800
satellite 119w
12472 L
tp 18
channells
146/239/418/424/427/436/438/572/
12486 R
tp 19
channells
200/202/303/320/333
satellite 121w
12016 V
tp 21
channells
733/734/737/738/761/766
satellite 129w
none
satellite 148w
12486 R
tp 19
channells
607/609/615/620/778
hope this helps
Username: Nash04
There is no "FIND" button on ultra.
Username: Bones714
Saigon, sO.C...
Post Number: 210
I get 7 days with my Sonicview 1000 automatically, but my pansat 2500 is just terrible. Sometimes i have to wait 2-3 min just to get the next hours shows listings
Username: Joed
Post Number: 15
On my VSx I just put it on 200(cnn) or 2211(global) and it populates the guides in 30 seconds.
