Gold Member Username: Mc_sunnyPost Number: 1062 Registered: Feb-06 | Hi guys this my first HDTV i got it from futureshop for 1699+tax...I just wanna to know did i pick up a good tv with nice deal or wut ? And can you tell me how can i make my pic quality better...SHOULD I GO WITH HDMI OR companat vidoe cables....i am new to HDTV, so plz tell me more about this...i wanna gather more info as much i can..Thanks |
Silver Member Username: TapemanPost Number: 451 Registered: Oct-06 | Hi McSunny 1699 is OK there were better deals on different products First thing you need to know what HD reciver to plug - i.e. Is it HD Antenna, Satellite, Cable, etc. - Based on that you can decide HDMI or RGB - For antenna no need to HDMI $100 rip off - For Digital receivers/Decoders set the Wizard that will automatically change to 108i, 1080p, 720p, 720i, 480 etc. HDMI will be better picture if receiver is truely capable to handle it from optic port |
Gold Member Username: Mc_sunnyPost Number: 1063 Registered: Feb-06 | Actually it was 1599CA which is about 1325US These are the untis i hooked up to that tv right now Satellite...Dishnetwork but dishnetwork receiver is not HD......Using comapant cables Cable.....Normal CABLE... Dvd Player.... using comapant cables Xbox 360....I love the Game Pic it looks so nice...using Component HD/AV Cable i just bought that for 49.00CA - so wut u think the cables i am using are they good or anything i need to change ? |
Gold Member Username: Mc_sunnyPost Number: 1064 Registered: Feb-06 | component video cable* |
Silver Member Username: TapemanPost Number: 452 Registered: Oct-06 | $1325 sounds much better Most cable companies will charge $5 per month for an additional HD receiver. Ask your cable company if they can do that HD receiver good reciption. If they can do make sure it is the new optic one If they don't get a $70 TERK amplified antenna straight coax to your TV no need for HDMI. Will get your local broadcast ch 2-69 as long as they are within 50 miles radius (much better than cable) |
Gold Member Username: Mc_sunnyPost Number: 1066 Registered: Feb-06 | Thanks king, it was very nice of u to help me out on this. i will be coming in this section more often to learn more sutff..Thanks again |
Silver Member Username: TapemanPost Number: 473 Registered: Oct-06 | Hey McSunny Just like Satellite dish if you point antenna to get best reciption http://www.antennaweb.org/aw/Address.aspx You don't have to enter full info just city, state and zip the degrees will be Azmith King |
Gold Member Username: Mc_sunnyPost Number: 1096 Registered: Feb-06 | ok i will check this out..thanks |
