Silver Member Username: Camaro823British Colu... Canada Post Number: 928 Registered: Jun-05 | I'm looking at buying a cheap laptop, that runs fairly fast. Im gonna buy it form Future Shop since I have a $100 gift card, what do you guys think of this http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10083614&catid=2 4193&logon=&langid=EN Remember its in Canadian dollars |
Gold Member Username: James1115Use a simple... Post Number: 8883 Registered: Dec-04 | looks good, lots of ram |
Gold Member Username: WingmanaliveNj US Post Number: 3037 Registered: Jun-06 | Ram is good. |
Gold Member Username: James1115Use a simple... Post Number: 8886 Registered: Dec-04 | it is indeed |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3000 Registered: Jul-06 | certainlky isnt small 3k posts FTW |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3001 Registered: Jul-06 | not small i meant bad certainly isnt bad*** |
Gold Member Username: James1115Use a simple... Post Number: 8890 Registered: Dec-04 | 8890 for me |
Gold Member Username: WingmanaliveNj US Post Number: 3040 Registered: Jun-06 | I love this place! |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3005 Registered: Jul-06 | 6 months for me 2 years for you ill catch you in a year or 2 lol |
Gold Member Username: WingmanaliveNj US Post Number: 3041 Registered: Jun-06 | Wanna a pic war?? LOL. |
Gold Member Username: James1115Use a simple... Post Number: 8894 Registered: Dec-04 | I had about 3000 in my first 6 months also but I slowed down a whole lot after that. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3006 Registered: Jul-06 | yea ill reach a plateau and not post as much as i do now... |
Gold Member Username: James1115Use a simple... Post Number: 8897 Registered: Dec-04 | I go through stages where I will post 1000/month but then 30 posts the next month lol |
Silver Member Username: Livin_loud18 of Love Fi Audio Post Number: 940 Registered: Jan-06 | http://www.ubid.com/Computers_Office_Laptops/c1001.html ^^^^ best deals known to man well not really, but they're good... |
Silver Member Username: Motomattic3Post Number: 479 Registered: Oct-06 | not a fan of gateway I prefer Acer,Asus,Tohsiba,sony Acer is my fav though you can get a good laptop off of www.tigerdirect.com http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=17 |
Silver Member Username: Camaro823British Colu... Canada Post Number: 929 Registered: Jun-05 | Thanks, for the opinions, but i'm only buying from Future Shop, in your opinion what do you think of the specs on that laptop ? |
Gold Member Username: James1115Use a simple... Post Number: 8910 Registered: Dec-04 | they look good, what are you going to be using it for? |
Silver Member Username: Camaro823British Colu... Canada Post Number: 931 Registered: Jun-05 | Mostly school work, and work, need a fast internet connection. I will be using programs like quickbooks, and excel a lot. |
Gold Member Username: James1115Use a simple... Post Number: 8918 Registered: Dec-04 | the internet connection depends on your server not the CPU. That CPU is plenty for what you need it for. |
Silver Member Username: Camaro823British Colu... Canada Post Number: 932 Registered: Jun-05 | Alright, thanks bud |
Gold Member Username: James1115Use a simple... Post Number: 8970 Registered: Dec-04 | no problem |
Silver Member Username: Motomattic3Post Number: 484 Registered: Oct-06 | i just don't like gateway i don't think they make good quality computers and i think if ur gunna buy a laptop for what your lookin for you really don't need everything there you can get a good laptop for around $399-$499 that will do what you want it to just fine. but buying a gateway is like buyin a turd, thats my view anyway have had a lot of friends and family have bad luck with them. but hell people diss sony and I've had mine for 3 years now with no problems so maybe its luck of the draw. |
Silver Member Username: Motomattic3Post Number: 485 Registered: Oct-06 | speakin of which you know thats a refurbished laptop right? |
Gold Member Username: James1115Use a simple... Post Number: 9041 Registered: Dec-04 | I honestly didnt even realize it was a gateway, I just looked at specs. I have heard a few horror stories about them aswell but then again I have about Dell also and I have 3 of them and they are all great. |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1687 Registered: Jan-06 | Not only is it a Gateway, its also a refurb. |
Silver Member Username: Camaro823British Colu... Canada Post Number: 934 Registered: Jun-05 | yes its a refurb, but i've got 3 years warranty with it, and thats problably all i'll keep it for. |
Gold Member Username: James1115Use a simple... Post Number: 9047 Registered: Dec-04 | what does the warranty cover? parts and labor or just parts? |
Silver Member Username: Camaro823British Colu... Canada Post Number: 935 Registered: Jun-05 | Parts and labour, it takes over from the factory warranty, so even if something goes wrong during the factory warranty, Future Shop will still fix it. |
