Stumped
Username: Catalepsyjustin
whenever i turn the volume up on my system the amp goes into protection mode, but it was running fine for 7 months. ill seriously give 10 bucks to whoever knows.
Username: Carguy
Post Number: 5848
You need to adjust the gain/level on the amp properly. Just cause it was working for "7 months" before doesn't mean it'll keep on working. With electronics, if abused, it'll gradually die over time.
Also check the voltage going into the amp when it goes into protection. The amps shut down from either signal overload or lack of power.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 947
check your VC. last time that happened to me, my VC looked like thisUpload
Username: Warlok
Orlando, FL USA
Post Number: 185
Nice !
Also, make sure you are not running your amp on a load it cant handle .. . .. .
