Bronze Member Username: KillemallEdmonton, Alberta Canada Post Number: 20 Registered: May-06 | I got a pair of L7 12s and am having troubble on deciding what size and type of box to build. I like to listen to alot of hip-hop and rock and want them to get loud but want some decent sound quality out of them as well. ive got enough space to give each sub a good 2.5cubes of space and am not sure if i want to go ported or sealed. Any suggestions would be appreciated. Tyler |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3677 Registered: Sep-04 | 4 cuft 36 hz. lots of port area 8) |
Silver Member Username: Solobaric4lifeSeminole, Al United states Post Number: 121 Registered: Jan-07 | go 2 www.proboxrocks.com and check out the dual square boxes its the super bass model my bro has the 1 for 2 solo 10s and there loudest 2 10's i heard in my life lol they beat my new model solo 12's in a sealed lol if u got room for it it will be loud |
Silver Member Username: TanmanfoshoFi SSD15 Wangers Post Number: 748 Registered: Nov-06 | making a box would be much much better. or have someone on the forum make u one. their pretty much amazing |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 11228 Registered: Jul-05 | "beat my new model solo 12's in a sealed" Never seal Kicker square subs...it is a waste... |
Bronze Member Username: KillemallEdmonton, Alberta Canada Post Number: 21 Registered: May-06 | I dont have a clue how to build a ported box but im definitly not scared to try. Does anyone know of any websites that would assist me on how to build and tune a ported box? |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 2937 Registered: Jul-06 | http://www.subwoofertools.com/forum/ported-box.asp http://www.the12volt.com/caraudio/caraudio.asp http://www.bcae1.com/ its not too hard...plus we'll help if you need it |
Silver Member Username: Solobaric4lifeSeminole, Al United states Post Number: 123 Registered: Jan-07 | the end, i had to get a sealed believe me if i had enough room for ported i would really have it, but its in a camaro and i dont wanna take my seat out, and under the hatch is just not enough for a ported for those solo 12's but i would love a ported, but like i was sayiny anyway ima get for suuuure 1 fi btl 18 with all good opions and stuff and ima put that in a blazer for starters lol |
Bronze Member Username: KillemallEdmonton, Alberta Canada Post Number: 22 Registered: May-06 | Whats the L7's Xmax and Driver diplacement? Trying to find it online right now |
Silver Member Username: Trey4sportsPost Number: 373 Registered: Sep-06 | kicker doesnt list it |
Silver Member Username: Solobaric4lifeSeminole, Al United states Post Number: 126 Registered: Jan-07 | the xmax on the l7 12's are .51 in but dont know bout other |
Bronze Member Username: KillemallEdmonton, Alberta Canada Post Number: 23 Registered: May-06 | How different would a 4ft3 box at 32hz sound from a box thats 4ft3 at 36hz. would you notice any sound difference by ear? |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 374 Registered: Nov-06 | i think u actually can hear a difference (nvr tried it before but i think it should make a difference) but plz correct me if im wrong |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3688 Registered: Sep-04 | yeah im sure you can hear a difference. 32 will have a little lower end extension but L7s are just made to be a loud piece of poo lol |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 398 Registered: Nov-06 | literally 'poo' |
Bronze Member Username: _jw_OH Post Number: 46 Registered: Jul-06 | Do 6.5^ft tuned to 34hz with 70-80 sq in of port. |
Silver Member Username: BasssquaredPost Number: 119 Registered: Nov-06 | yeah but if i had two rockford P1s then two L7s are a huge improvement right? |
Bronze Member Username: _jw_OH Post Number: 50 Registered: Jul-06 | Night and Day. |
