Shallow subs
Username: Nitrofour
Post Number: 30
anyone know if these are actually of any decent quality? this is all i can fit in my trunk since i have limited space in there due to convertible top... i'm thinking of putting 2 of these:
http://cgi.ebay.com/ebaymotors/Pioneer-1200-Watt-12-Subwoofer-Shallow-Sealed-box _W0QQcmdZViewItemQQcategoryZ38646QQihZ007QQitemZ170074455175QQrdZ1QQsspagenameZW D1V
but the thing is... is it even worth it? should i even bother? will i hardly hear anything anyways?
Username: Denali_on_22s
SSX, Tenneki US of A
Post Number: 1030
Of course you'll hear something. I've heard good reviews about those subs. They just need the right install.
Username: 54danny54
KY More Wang Th...
Post Number: 3287
[img]http://blaise.us/emots/blowup.gif[/img]
lol this is a test
but yea id go with the infinity basslink if space is an issue
look on crutchfield.com for em
Username: Budling
Cali USofA
Post Number: 167
The sub that they have pictured isnt the right one.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17005
Nj US
Post Number: 3062
Danny, right click on the smiley and save it to your hard drive. Then use the upload image or attachment button down below.Upload
Username: Budling
Cali USofA
Post Number: 168
Or Infinity.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4643
Username: Nitrofour
Post Number: 31
okay so if i put two pioneer TS-SW3041D... what would that compare to? i'm afraid i'll put in the $170 for the subs and then $170 for the amp and i won't feel a thing, or they'll just blow or something, they sound so cheap
thoughts?
Username: Budling
Cali USofA
Post Number: 169
Or Kicker.
http://www.kicker.com/06/kicker_home.html
Username: Nitrofour
Post Number: 32
what do you think would be the highest quality (spl and sql): the kickers, the infinitys or the pioneers?
Username: Budling
Cali USofA
Post Number: 170
If you put them in the right box and power it with the right amp with gain set properly, I dont see why it would sound good. Pioneer makes some well built shyt. Just do a google search on those subs and read all the reviews.
Username: Budling
Cali USofA
Post Number: 171
Spl - Pioneers
Sql - Infinity
Username: Nitrofour
Post Number: 33
i'm assuming the kicker ones you mean are the 10" compvx's
Username: Budling
Cali USofA
Post Number: 172
CompVT
Username: Nitrofour
Post Number: 36
okay i want the quality over power, so i'll go with two of the infinity kappa's... thanks so much woofer...
what should i use to power them that's good quality? they are: power range: 50-350 watts RMS (1400 watts peak power)
________________________________
also: i have 7 1/4" maximum vertical height in my trunk, will the infinitis plus the size of the box they're in still be able to make it under a total of 7 1/4" ?
Username: Nitrofour
Post Number: 37
would this box be good for housing the infinity:
http://cgi.ebay.com/12-REG-CAB-TRUCK-SUB-BOX-U-ENCLOSURE-4-SUBWOOFER-NEW_W0QQite mZ140076487106QQihZ004QQcategoryZ50568QQrdZ1QQcmdZViewItem
Username: Nitrofour
Post Number: 38
sorry what i mean in this box (for two of them instead): http://cgi.ebay.com/DUAL-12-TRUCK-SUBWOOFER-SUB-BOX-U-ENCLOSURE-4-SUBS-NEW_W0QQi temZ140076350142QQihZ004QQcategoryZ14945QQrdZ1QQcmdZViewItem
Username: Nitrofour
Post Number: 39
damn nevermind that dual one, my trunk isn't that wide
Username: Budling
Cali USofA
Post Number: 175
It would be a tight fit.
Username: Nitrofour
Post Number: 40
damnit all these boxes are 20" wide and my trunk is only 36" wide so i don't know how i'd fit two of these infinity's in there
Username: Budling
Cali USofA
Post Number: 176
Whats your price range for the amp, and are you gettin to subs or one?
Those sub are 5" deep. Your mounting these with the subs facin up?
Username: Budling
Cali USofA
Post Number: 177
I meant two subs?
Username: Nitrofour
Post Number: 41
woofercooker: would it just be better to get two BAZOOKA BTA10200 10" AMPLIFIED 200 WATTS enclosures and put them in my trunk instead of the dual infinity setup. the bazookas will fit, but i have a good feeling that no one ever talks about them because they're terrible? but i'm not sure
Username: Budling
Cali USofA
Post Number: 178
You could get two boxes and put them top to top.
Username: Nitrofour
Post Number: 42
in response to your post above, my price range is not an issue for the amp as long as it's under $300, i don't care how i mount them, but i seriously don't think i'll be able to fit two of those in my trunk if it's 36" wide, 7 1/4" vertical with the last 8" or so being about being twice that height. so now i'm thinkin about those bazookas unless you knwo away around all this?
Username: Budling
Cali USofA
Post Number: 180
No. I would get the Infinity Basslink before I would get the bazooka, but no.
Username: Nitrofour
Post Number: 44
wait a minute, i'm seeing a way i can position everything so it works. but i'd have to put each one of the infinity's in their own box... will that greatly reduce the sound?
Username: Budling
Cali USofA
Post Number: 181
"but i seriously don't think i'll be able to fit two of those in my trunk if it's 36" wide, 7 1/4" vertical with the last 8" or so being about being twice that height. so now i'm thinkin about those bazookas unless you knwo away around all this?"
Explain this a bit better H x W x D
Username: Budling
Cali USofA
Post Number: 182
That is what I just said. It would sound the same.
Username: Nitrofour
Post Number: 46
hmm okay i'll do that, thanks so much i really appreciate you taking the time to answer my questions, so i have one last one for you :-)
amp suggestions?
Username: Budling
Cali USofA
Post Number: 183
Give me a min and I will suggest some amps.
Why are you goin with a truck style box? Why not a hatch back style?
Username: Nitrofour
Post Number: 47
i'm not sure what you mean by hatch back style, but that box i showed you (http://cgi.ebay.com/12-REG-CAB-TRUCK-SUB-BOX-U-ENCLOSURE-4-SUBWOOFER-NEW_W0QQite mZ140076487106QQihZ004QQcategoryZ50568QQrdZ1QQcmdZViewItem)
fits in my trunk so that's all i know, are you saying there is something else that would fit? maybe you mean this (http://cgi.ebay.com/NEW-CAR-AUDIO-DUAL-12-WOOFER-REAR-FIRE-HATCH-SUB-BOX-U_W0QQi temZ140076549354QQihZ004QQcategoryZ14945QQssPageNameZWDVWQQrdZ1QQcmdZViewItem) but that vertical mounting depth is too high anyway
Username: Budling
Cali USofA
Post Number: 184
http://www.sonicelectronix.com/item_4336.html
http://www.sonicelectronix.com/item_7559.html
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16918
One of those with two Infinity KAPPA122.7W wired down to 2ohms.
Go with the kick. There are some more out there, but ive got to go to work, so maybe someone else can suggest a few. I will be back on later tonight.
Username: Nitrofour
Post Number: 48
that kicker is a mono amp though, doesn't that mean i can only power one of the infinity's off of it? so what you're saying is get two of those kickers? i think that's too expensive to get two of those for these cheap little subs, no?
Username: Budling
Cali USofA
Post Number: 185
Yeah that type of box would be better because they are usually deeper and not as wide. Also the angle is on the back side. This is so you can face the subs backwards and push the back of the bow against the seat. A truck style box has the angle on the front.
Username: Budling
Cali USofA
Post Number: 186
No you just need one. You just wire the subs in paralell. Just do a google search on how to change ohm load and wiring sub series or paralell. If you cant figure it out, I will be back on at about 11:00pm pacific.
Username: Nitrofour
Post Number: 49
do you think i should just power them both off of this:
http://cgi.ebay.com/NEW-KICKER-ZX850-2-TWO-CHANNEL-CAR-AMPLIFIER-AMP-2-ZX_W0QQit emZ290075029634QQihZ019QQcategoryZ48598QQrdZ1QQcmdZViewItem
Username: Budling
Cali USofA
Post Number: 187
Im not understanding why you need a shallow mount sub if your puttin this in your trunk. Were you tryin to match the sub to the truck style enclosure?
Username: Budling
Cali USofA
Post Number: 188
"do you think i should just power them both off of this:"
No!!!!
Username: Nitrofour
Post Number: 50
because my trunk is 7 1/4" tall. i have a convertible and the convertible housing shelf takes up 99% of the trunk space leaving me with a vertical depth of 7 1/4"
Username: Budling
Cali USofA
Post Number: 189
You will be wiring the subs together making it one channel(mono) at 2ohms.
Username: Budling
Cali USofA
Post Number: 190
Ok well the sub require .5-1.0 cuft sealed.
So what ever box you get that fits your car just make sure that its .5-1.0. Thats the only thing you will have to worry about with the sealed enclosure, that and get a box that allows you to face the subs towards the back of the car. And try to get a box with 3/4 mdf.
Username: Nitrofour
Post Number: 51
k so i'll go with the kicker suggestion then http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16918
Username: Budling
Cali USofA
Post Number: 191
That amp will be perfect for those subs.
Username: Nitrofour
Post Number: 52
ok then it's settled. let's hope these shallow speakers don't distort and sound like crap
