Silver Member Username: Dmm2005DD Audio ORION, Warren Count... USA Post Number: 478 Registered: Aug-06 | Does anybody know the outer diameter of a 9515? im doing a double baffle on a box im building for a friend and im thinking about settin the sub down in the box to flush mount it |
Silver Member Username: Nd4spd18Post Number: 191 Registered: Jul-06 | Is this what you're looking for: http://www.ddaudio.com/dd/caraudio/enclosureInfo/mountingData.asp |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2860 Registered: Nov-05 | should be 15.5" .. most 15s are that size for the basket |
Gold Member Username: DrivingrecklessDD 9515f, USA Post Number: 2776 Registered: Apr-06 | not sure but if u would like wen i ger home ill measure it but im guessing 15.25 b/c the cut out hole is 14.25 |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2862 Registered: Nov-05 | ... the hole cut for my SX 15" is 14" and the outter diameter is 15.5" the cutout means nothing for the baskets outter width |
Silver Member Username: Dmm2005DD Audio ORION, Warren Count... USA Post Number: 480 Registered: Aug-06 | it says 15.5 on the website...i guess i thought it wasnt on there cuz i couldnt find it for my 1012s. ill probably go a little bigger than that so i can get them out easier. Thanks!! |
