Is it possible to bridge Kicker ZX750.1 and if so, what can you bridge em to...aka how many watts and at what ohms will it be pushing...is there anyway to hook up three single 4-ohm voice coil subs to either a Kicker ZX1000.1, 2 ZX750.1s, or a ZX1500.1 ?
375 watts RMS x 1 @ 4 ohms 750 watts x 1 @ 2 ohms It seems you can run 2 Ohm mono(bridged). But can you hook up 3-4ohm SVC subs? Tecnically, yes, you can, BUT . . . you would be running out of the safe operating rance of the amp. If you did that, it would leave your Impeadance at 1.33 Ohms. I never tried it, but Ive heard people say they ran thier amp at an unsafe ohm loads, but it worked fine. IMO, thats a quick way to F*K up your equipment. Now if it was closer to 2 ohm(1.7+), I would say go for it, but 1.33. . iffy IMO.
And NO, none of those amps aove are 1 Ohm stable, and unless they were, I would run them at tha low of a impedance. I believe Hifonics BXi1606D will work like a charm give your desires. But you already have a nice amp(s) right now.
