Username: Fatkid tonawada,
Ny
Post Number: 98 Registered: Dec-05
Wednesday, January 24, 2007 - 16:26 GMT any one ever use a air stapler with liquid nails to build abox
Username: Stnorris Davenport,
IA
US
Post Number: 1971 Registered: Apr-06
Wednesday, January 24, 2007 - 16:28 GMT no u should stick with screws and liquid nails
Username: Southernrebel Monroe,
Louisiana
DD 9515d~~]...
Post Number: 4215 Registered: Mar-04
Wednesday, January 24, 2007 - 17:14 GMT I usually use screws, but i did get to use a buddies nail-gun awhile back to build his box. It was faster putting it together, didnt have to worry w/ counter-sinking screws. That box is a rock too! 4.5cuft net w/ interchangable ports. Did 145.1dB w/ an MTX 8500 15" on 800wrms. As long as you use good glue and your nail-gun will 'pull' the panels together, nail-guns are just as good as screws. The glue is what actually holds the box together...the glued joint (w/ good glue) will actually be stronger than the panel itself. For glue, I always use Elmer's Wood Glue or Gorilla Glue. Gorilla expands as it drys though...if you have a few small gaps you may want to use it. (more expensive though) Elmer's Wood Glue is good stuff. Titebond is also dam strong glue. I really dont like using Liquid Nails. That stuff is actually designed to provide a flexable joint...and that is a no-no for sub boxes.
Username: Phil_salisbury Post Number: 143 Registered: Sep-06
Wednesday, January 24, 2007 - 19:39 GMT Been using an Air Nailer ever since I started this business for build enclosures. If your box parts are cut clean, true and square, assembly is a breeze with brad nailer/ And Canaan is correct, Liquid Nails is crap for building subwoofer enclosure's since it does not create a bond like a good wood glue.
Username: Livin_loud 18 of Love Fi Audio
Post Number: 925 Registered: Jan-06
Wednesday, January 24, 2007 - 19:57 GMT ^^^ ya learn somethin new everyday...
Username: Frkkevin Resonant Engineering...,
Fort Worth...
Email
Post Number: 2807 Registered: Nov-05
Wednesday, January 24, 2007 - 20:05 GMT Wood Glue FTW! ...btw.. told you liquid nails is poo Chad
Username: Bestmankind Www.15inchwangers.comFI Audio BTL
Post Number: 9697 Registered: Oct-05
Wednesday, January 24, 2007 - 20:13 GMT yeah i got it. since phil and canaan both say its no good.
Fort Worth...
Email
Post Number: 2809 Registered: Nov-05
Wednesday, January 24, 2007 - 20:15 GMT i see how it is.. don't trust me .. lol
Post Number: 9698 Registered: Oct-05
Wednesday, January 24, 2007 - 20:16 GMT i am just playin buddy. my next box i was gonna use wood glue after you mentioned it. lol. seriously kev. after you told me wood glue i believed you.
Fort Worth...
Email
Post Number: 2810 Registered: Nov-05
Wednesday, January 24, 2007 - 20:18 GMT haha.. when you starting another box?
Post Number: 9700 Registered: Oct-05
Wednesday, January 24, 2007 - 20:20 GMT after this weekend. i am designing a box in my head as i type this. lol.
Username: Logan__tille [:-]15 Wangers Club[:-] Premier Member
Post Number: 5034 Registered: Feb-06
Wednesday, January 24, 2007 - 22:08 GMT i wanna make a box
Username: Wingmanalive Nj
US
Post Number: 2998 Registered: Jun-06
Wednesday, January 24, 2007 - 23:18 GMT Logan.
Username: Rovin 1 12 Atomic ...
Post Number: 10515 Registered: Jul-05
Thursday, January 25, 2007 - 03:52 GMT Guess im a die hard liquid nails fan cause its still my fav but hey its all good ........
Username: Kaos15th Post Number: 385 Registered: Mar-05
Thursday, January 25, 2007 - 21:11 GMT i use wood glue liquid nails dosent do it for me
