New Ariza Extreme File
Username: Nydas
Post Number: 1647
Ariza Extreme Fix. NOT for Ariza 7xx.
Reported working very well. I have not tested it myself.
VS Xtreme fix 07-02-02
C/P
- Dn/BEV B1 Autroll Routine Fixed
- Specified Channel - In theme menu you can store 3 keyword
- Radio Screensaver On/Off
- Beep (Remote Control Unit)
- LNB Setting - When you change satllite LNB option is being set if the option of the satllite was not saved
- Channel Edit Program (PC release soon)
[link removed]
Username: A6ali
Toronto, Ontario Canada
Hi nalin
I want to ask you what size of dish i need to use for the 121 west and for 148 west
both dish should be of same as 18'' inch or differnt
Thks
Username: Nydas
Post Number: 1654
For 121W use at least 20" for the Ku band (TP higher than 11000).
For 148W. 18" is fine
Username: Ubba
Post Number: 18
Hi Nalin,
This new bin is a totally different number with a DX in front than the usual ones. Is it safe for Ariza Xtreme? Please advise
Username: Nydas
Post Number: 1667
It was posted as Ariza extreme and now it has morphed itself into VS extreme fix!
You are right. It is probably a VS fix and not an Ariza fix.
DO NOT USE IT.
