Ps2 problem
Username: B0ngbong
NEW YORK, NEW YORK USA
Post Number: 7
i start having problem with ps2.Everytime i turn on the game it always go to the brower,configuration window i tried it 100 times
and always the same thing.Can someone tell me what is the problem with my ps2.
Username: Jakdaxtersgirl
Post Number: 443
That is the main menu...I tried w/ my Ps2 & it did the same thing so nothing's wrong w/ ur Ps2
Username: British_power
Post Number: 1295
ya its just the menu...it happens 2 my ps2 everytime
Post Number: 444
yep
Post Number: 1299
hey jak put me on ur buddylist...my screen name is Runningstud24
I just got a 2nd hand ps2 it worked fine for the 1st month but now it's doing strange things. for instants i just got a new game about two weeks ago and the ps now sometimes freezez and it seems to be getting worse it now wont load my other games HEALP!!!!!!!!!!!!!!!!!
Post Number: 1311
here is my advice...dont buy used electronics...u dont know y they r giving it away...they could have dropped it
Username: Warriors
Topeka, Indiana United States
well you know why they brought the new ps2 out the booklet or w/e well cause the old one has recalls I have had 5 of the old ones and they have all blown up and now that is why they came out with booklet so yea
my ps2 is not loading auy of my games.i need help
Username: Andrew149
Raleigh, NC United States
you guy are all idots mabby you should take care of them i had mine for three years not one problem when you hook them up to one leave it their and make sure it a safe place so it wont fall and brake
Username: Spanky34
IL
Post Number: 33
its cause ur laser needs cleaned. You google "cleaning ps2 laser" Figure out how to clean it. Most of the methods void your warranty though, if u actually sent in the warrant card.
Username: 30003r
LondonEngland
Post Number: 8
notin rong with ps2 open it up and just shake the laser by grabing it from the sides.
Username: 30003r
LondonEngland
Post Number: 9
but make sure u clean them before u do that
Old Gamer
My older PS2 wont play certain newer games. Game stores have told us to put duct tape on the top to correct it. Does this really work?
Meri
Duct tape fixes everything bizatch!!!
Then stick some damn Ducttape over ya mouth then - LOL.........
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2968
gaffers tape is better.lol
abbrdidsd
where do you put the tape?
Post Number: 4053
around the ps2
Username: Rideredder
Cornell, IL USA
Post Number: 149
Just open it up and take a Q-tip to the eye. I've had to do that to mine a couple of times and it works like brand new for about 6 months. When it starts acting up, just clean the eye again.
Username: Zantosx
hey when i open my ps2 it comes in black n white instead of colour plz can anybody help me with dat problem if yes dat will be great.
