I lost Bev about a week ago. Dish still works great. I'm running a pre March 2004 Fortec half panel (sue me, it's worked great) flashed as a Pansat 2300 using bin X-75BL-061027-261d(ir)E.api.
Fred what satscanner told you was good advice. You have a modded machine. If you want it to be easy go get a viewsat. I am sure you have a forum that helped you do that mod. Go back to their and get the latest mod. If you cant got o the home forum for the receiver your machine is modded to act like and find a clone safe bin for it.
The only way you can make a receiver work is, have it pointed and geting sat sig, have the latest update, and have the new key's.
Perhaps I didn't phrase my question correctly. I'm pointed correctly, don't have a problem with keys, and have been doing this for about four years now.
I visited other sites to try to find a bin that would get Bev back, but haven't been able to find one.
I simply wanted to know if the members on this site had any knowledge of where to point me.
It wasn't a tough question. A simple "Fred, at this time we know of no bin that can help you" would have sufficed.
Their is no known trouble with bev is the thing. The trouble has been with a few channels on DN oh and 2 or 3 on bev ( 2 aov p*orn channels and pl*ayboy )
so what bin do you have loaded now? You may have...a bad receiver now?
Actually Jay, Pansat bins are giving many people fits, because Pansat never really had a good fix for the map 57 ECM...but Fred has NO choice but to use Pansat 2300 bins , since Fortec quit makings bins for Fortec half panels..
Fred , as U should already know your best bet is Future fta.info or al7bar.*tk sites for pansat 2300 files...that will be the first place to have the bin, when/if its posted..
this Ocober 27 bin is still the latest 2300 release at ALL sites...as an halp panel owner, U should know all this, about lack of bins and which sites to use...this is a common problem for all half panel owners!...breakdown and upgrade that antique!...don't come here expecting "guidance and direction" , if U had that for 4 years now...U should be helping other halp panel owners, not critsizing non halp panel owners here!...U posted like a newbie , and got replies based on your post!
x-75bl_061027_261e_api 2300.zip is the latest!...like cars, U can't get parts for the antiques and old ones...they are hard to find!
