Box corner question
Username: Spandmh1
Tunnel hill, Ga CANT WAIT... Usa
Post Number: 188
if you round the corners with a lil strip of MDF will it affect the tuning in any way?
Username: Extrmndor3
Sit and Look pretty
Post Number: 3382
dude everything will afeect the tuning but will not be able to tell the diference like if you put resin it will affect the tuning too but will be around 2hz -/+ if diference and you will not be able to hear the diference only the termal lab
Username: Spandmh1
Post Number: 189
oh alright. thanks man! i was j/w
Www.15inchwangers.comFI Audio BTL
Post Number: 9729
if you want to go exact then calculate the displacement of those corners matt.
Username: Frkkevin
Post Number: 2830
it would not throw it off that much unless the corners were huge.. so no worries
Username: Spandmh1
Post Number: 190
alright thanks guys. im tuning it to 40hz so if it goes up or down by just like 2 or 3 i wont care prolly.
Post Number: 9734
now that changes everythign matt. if you are tuning to 40hz you shouldn't do the corners like that.
just playin. you will be fine.
Username: Spandmh1
Post Number: 191
lol. dont scare me u b@stard! haha. i cant wait til tomorrow man! the sub will be here... FINALLY! took a whole 4 days... im pretty impatient :-)
Username: Rovin
1 12 Atomic ...
Post Number: 10508
i agree
with a 40hz tuning most u can lose wouldb= be about a 2hz if so much so d\IMO dont lose sleep over it -lol ......
