Need Some Help Pickout Out An Amp
Username: Stuckinutero
Budget- $220
Current System Includes-
Alpine CDE-9852 Deck-
http://www.crutchfield.com/S-72MZDKyTQrS/cgi-bin/ProdView.asp?search=9852&i=500C DE9852
MB Quart 5 1/4 Components up front. 90 Watts Max RMS
http://www.crutchfield.com/S-72MZDKyTQrS/cgi-bin/ProdView.asp?search=rua213&i=04 9RUA213
Alpine Type-R 6x9s in back. 55 Watts Max RMS.
http://www.crutchfield.com/S-72MZDKyTQrS/cgi-bin/prodview.asp?I=500spr69lp&searc h=69lp
I specifically bought the Type-R's because I heard they give off exceptional bass. I drive a 97 Prelude and have always been reluctant to accomodate the weight of subs in my trunk. If the current sytem I have amped up doesn't please me then Ill move onto subs.
Right now I just need help finding the best amp I can for $220 or under. Thanks for the help.
Username: Alexv305
Tavernier, FL USA
Post Number: 576
save the money of the rear deck and use it on an excellent front stage.. will sound nicer and easier to pick out an amp...
You misunderstood. I already have all of that in the car. I put some serious thought into what you suggested a few months ago, and from the people I talked to it only works well if you run subs and an audiophile quality amp.
I have a home recording studio that im a few grand into. Spending that kind of dough in my car never even entered my mind.
I could spend 6k on an amp right now if I wanted to. Not gonna happen though.
One thing thats always blown my mind about any car audio forum is how people looking for real cheapo crap always get tons of input. Im always willing to spend twice as much and I always get the "save, buy better sh*t" response.
Just looking to spend a max of $220 on an amp. Most companies producing amps I've never even heard of. Besides your Alpines and your Rockfords its all new to me.
Post Number: 7
Maybe this?
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13704
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 4894
thats a nice amp
Post Number: 8
Thanks, thats all I really needed. Like I said, I have no clue when it comes to amp manufacturers.
Just one more piece of advice. Im trying to decide between that amp and an Alpine one (Ill post the link below). I figure the Alpine might be a better idea, and worth the extra dough because Im already running an Alpine HU and Type-Rs in the back.
Heres the link.
Alpine MRP-F450
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16956
Post Number: 5032
the PPI is a better amp.
Post Number: 9
The PPI it is. Turns out I have another small job on my hands before I go to the amp.
I'm the 3rd owner of a 97 Prelude. Unfortunatly there weren't many of these great cars made.
Even more unfortunate is the fact that the previous owner absolutly mauled the wiring inside this vehicle.
I'm off to tear some things apart. Thanks for the feedback, Ill more than likely go with the PPI amp now.
