Autotek SX-2300
Username: Ckelley
Post Number: 52
I've never heard autotek before but i have read posts about their amps before. I have a guy selling the sx2300 for $150.Is it worth it????? I know the reg. price is much higher.
Also how would work on my 2 Fi audio X 12's on a factory alt.( not sure about power consumption on these amps.)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3993
the model is very good. But let me tell you something. That's an A/B amp that will pull a lot of current from your alt. Amp's quality is very good and you might see 900w-1000w rms at 14.4V
If i were you, since you're using a factory alt, i'd grab a class D amp.
Are those subs dual 4 ohm or dual 2 ohm???????
Username: Ckelley
Post Number: 53
the subs are dual 4 ohm. How about a Memphis 16-PRD500.1 and run them at 1 ohm?
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 4888
that would work
Username: Ckelley
Post Number: 54
Would this be better and draw less current??
JBL GTO601.1 II
Username: Juliob
Post Number: 3994
if the subs are dual 4 ohm, you need 600w rms at 1 ohm. IDK if that jbl is one ohm stable
Username: Ckelley
Post Number: 55
What would be a good amp for me?
Username: Juliob
Post Number: 3998
pg xenon 600.1
Username: Ckelley
Post Number: 56
any other suggestions.
need 600 at 1 ohm
