Viewsat Ultra warning
Username: Mc_sunny
Post Number: 1002
ALL VIEWSAT ULTRAS SHOULD BE LOADED USING A USB STICK TO MINIMIZE LOADING PROBLEMS
Viewsat is aware of this and I'm sure will implement a change in future bins...if you DO NOT know how to flash with USB stick, Here is how to
-How to load with memory stick USB
Firmware Upgrade using USB flash drive.
Copy the firmware upgrade file to a USB flash drive.
Connect the USB flash drive to USB port in receiver.
Go to "System Information" than select "Receiver Upgrade."
Select USB and press OK button.
Select the firmware upgrade file and press OK.
When file transfer is completed, the receiver will be automatically reboot.
Note: If you do not see any files listed on your USB2 Flash Drive, power down Ultra using rear rocker power switch and in say 5 seconds power back up and follow above steps to get into loading files from USB2 Flash Drive into Ultra
Username: Mc_sunny
Post Number: 1003
Btw there aren't really any major issues except many peeps have problems when loading via serial cable..for example a "fail" message.
