Silver Member Username: Pannu16Post Number: 401 Registered: May-06 | Guys there r some changes made by dishnetwork so we are not getting half the channels. Blind scan does not work so channels have not been repositioned. Keys did not change. Its an ECM!! Viewsat is working perfect!! Pansat is hit, all clones like ariza eagle have been hit!! Satcruiser is hit too!! V GOTTA WAIT AND WATCH !! |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 341 Registered: Sep-06 | Here My pansat 3500 and viewesat is getting all of DN in the clear. you might want to check your key's |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 342 Registered: Sep-06 | I looked in several other forum's no post's regarding this "hit" ummm |
Silver Member Username: Pannu16Post Number: 402 Registered: May-06 | Bro i am talkin bout clones and cheap receivers!! i wrote that viewsat is working and pansar 2300 is not!! |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 343 Registered: Sep-06 | Can you refer us to a forum that is discussing this? So we can be ready if this is a hit we will be SLAMMED with questions here today |
Silver Member Username: Pannu16Post Number: 404 Registered: May-06 | i am tryin to fix 4 receivers right now!! so hold on for an update JAY!! I will answer ur questions. Let me figure out wats goin on!! |
Gold Member Username: PrfrmnjPost Number: 1415 Registered: Oct-05 | Jay - All my receivers working fine (Fortec / Pansat 3500 / Viewsats Plat-Ext) all working! Any ECM (well really change in stream) would have affected ALL receivers not just clones. But my Fortec is a clone of Pansat 2500, so if that is the case it should have stopped working. |
Silver Member Username: Pannu16Post Number: 405 Registered: May-06 | alright i have ARIZA 700 which i am fixing I have eaglestar to b fixed i also have Satcruiser to b fixed and i lost only half channels!! |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 346 Registered: Sep-06 | I thought that was the case if it affects one it will all....thanks we may need to wear some waders or boots to be sure and get any of B.S. on us in this thread but who know's..... |
Silver Member Username: EdenmanPost Number: 223 Registered: Aug-06 | Having trouble now with CW 600S Premium and CS 4000 clone. Mabe just a glitch, but those 2 are black screen on alot of bev... VS Platinum working fine. Go VS! |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 347 Registered: Sep-06 | now its bev too? |
New member Username: ThegimmerPost Number: 1 Registered: Dec-06 | It seems that Bev has started moving the PPV, Adult channels, and Events to the provider ID 904. This is the same thing that they have done with the NFL Sunday Ticket. The 0904 IDEA keys are being sent down in the cams private EMM-S keyset, meaning you would have to have an active sub. After ordering in the program, the keys are sent to that cam. For Sunday Ticket, the keychanges were taking place every 15 to 20 minutes during gametime. In my opinion, due to the many expected key changes (as proven for Sunday Ticket), AR is needed for those providers. Expect them to move the PPV, Adult, and Events to the 0904 provider. As usual, we may have to let this play out for a little bit before coders can take a look at this to react to it. Today, Bell has added all the adult channels, PB channel, and 1615 A&E. |
Bronze Member Username: JoedPost Number: 11 Registered: Sep-06 | The coders have had a lot of time to look this already via the NFL. If it was fixable I suspect the NFL would have been fixed. Hope I am wrong on this or it's bye bye to Free TV. NFL must have been the test for them and it appears to be working well. |
New member Username: JdrocciLisle, Ont Ca Post Number: 5 Registered: Dec-06 | Hello I have a 2700a Pansat, my echo 7 is dropping every 5-10mins. I turn it off twice and it appears again. In 5 mins it happens again, over and over. I repeat the steps and it continues to drop. Could someone tell me what is wrong. My Echo 6,8 is fine....... jr |
Silver Member Username: NikkPost Number: 883 Registered: Sep-06 | what do you mean when you say dropping...??? |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 333 Registered: Nov-06 | i got a FLU and only 3 of my channels are working....turned off rec and did reset and made no difference....but i am using a 286t bin so im thinkin about updating it..possible it mite work...hope so |
Silver Member Username: EdenmanPost Number: 225 Registered: Aug-06 | I dont think thats the problem, my CW Premium tells me provider info on every channel, and while PBoy and aov HAVE indeed been moved to 09 05, the new black channels are still 09 01 (even re-scanned). Perhaps it just hasnt updated yet, but my guess is its something new. |
Silver Member Username: EdenmanPost Number: 226 Registered: Aug-06 | 287t is a no go too. |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 334 Registered: Nov-06 | i think they have 290t now? |
Silver Member Username: EdenmanPost Number: 227 Registered: Aug-06 | 290t is for 2700's. |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 335 Registered: Nov-06 | o ok.. |
Silver Member Username: Pannu16Post Number: 406 Registered: May-06 | SO WAT DO U GUYS SAY NOW!! I AM NOt BS!! GUYS LOOK AT MY POSTS AND ALL POSTS ARE GENUINE TILL TODAY!! IT IS GIVIN PROBLEMS BUT NOT FOR EVERYTHING!! I AM STILL WORKIN ON THESE RECEIVERS!! |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 336 Registered: Nov-06 | pannu..i dnt kno....feel like throwin my flu out da window and orderin me a mag or somethin....im thru wit this bs now...but i still need tv till i get new rec. lol dunno wht to do |
Gold Member Username: LklivesPost Number: 7150 Registered: Jan-06 | Its a Bev issue even with the Magnum...looks like all receivers now..there was a Bev key change this morning too though.. |
New member Username: Vhl71Post Number: 6 Registered: Jan-07 | my ariza 700 is still up and running..both bev and DN..its about 2.50est now!! go figure!! |
New member Username: ThegimmerPost Number: 2 Registered: Dec-06 | PD, Venus, A&E, Drive in, Diva, Scream, Action are all black.... |
Gold Member Username: LklivesPost Number: 7152 Registered: Jan-06 | Many sites are reporting problems now, and all receivers...mostly all BEV...and no problems with plastic yet.. BTW...there was a Bev key change today...so check yours!...new ones are.. Nagra2 Keys Dish Provider 0101: Last Updated (Jan08 8:36pm EST) Key0: 7B A3 12 F7 A3 07 68 38 87 2D E3 D5 A1 09 51 11 Key1: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A (Active) Bev Provider 0901: Last Updated (Jan18 12:00pm EST) Key0: 76 3A 51 F9 0C 98 26 55 52 C6 BD BF C6 09 C7 C9 Key1: FB 31 EC 24 45 8E D5 EF 36 36 F8 1C C9 8F A5 71 (Active) |
Silver Member Username: NikkPost Number: 890 Registered: Sep-06 | Trusted Sites are fully saturated, something is on the air....... |
Silver Member Username: Mc_sunnyPost Number: 968 Registered: Feb-06 | MAP 57 is back. If you don't have plastic(rom102/103) or a veiwsat(FTA) your out of luck. Viewsat was coded for this MAP call. |
Gold Member Username: PrfrmnjPost Number: 1416 Registered: Oct-05 | I just went home to check my receivers. So far everything is working (DN) Fortec, Pansat & Viewsats. There are reports everywhere that these were not working. I could be the tons of mods I've done to my receivers that practically every electronic component in it has been moded, but I don't know. Anyone who had a working FLU before today can confirm if it's still working? |
Silver Member Username: Mc_sunnyPost Number: 969 Registered: Feb-06 | Here is some of the effected channels by MAP 57. PPV, p0rn, and some of the 300's, 200's, and 500's. |
Silver Member Username: Pannu16Post Number: 407 Registered: May-06 | dishnetwork is effected too!! not all channels but some channels on 61.5. Zee tv set max are just couple examples!! Viewsat is still working but ariza, eaglestar and co@lsat are gone!! also satcruiser is not working!! |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 338 Registered: Nov-06 | Mc Sunny!!! Good to see u bak..where u been? havnt seen u for a while |
Gold Member Username: PrfrmnjPost Number: 1419 Registered: Oct-05 | Mc Sunny - I just checked (abotu an hour ago) p0rn and at least the ones I check were working. I am going to check again when I get home, but an hour ago when I left everything was working. |
Silver Member Username: Pannu16Post Number: 408 Registered: May-06 | Thats it!! ECM has hit! Everything is gone!! New bins!! |
Silver Member Username: Pannu16Post Number: 409 Registered: May-06 | VIEWSAT IS STILL UP!! Everything else is gone!! lost all channels on 61.5. !! ECM TIME !! CODERS LETS GET BACK TO WORK!! |
New member Username: Vhl71Post Number: 7 Registered: Jan-07 | pannu..i don't know what are you on about..my ariza 700 is working..ppv, espn the whole lot..its 3.35pm EST |
Silver Member Username: HanzPost Number: 169 Registered: Oct-06 | Do you guys work from home or something? LOL! |
Silver Member Username: Mc_sunnyPost Number: 970 Registered: Feb-06 | sup Arslan, i been lil bussy |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 339 Registered: Nov-06 | good to see u bak |
Silver Member Username: Mc_sunnyPost Number: 971 Registered: Feb-06 | thanks man |
New member Username: Vhl71Post Number: 8 Registered: Jan-07 | so how come my ariza is still up? something fishy?? |
Bronze Member Username: VividPost Number: 49 Registered: May-06 | Hello There For what this is worth, at this exact moment 4:01pm, I have (3) Different Pansat 2700 Clones, running DN 110, DN 119, and Bell 91, and ALL (3) are Excellent, and Everything is working just fine. All channels are there, in order, and accounted for. PPV (saw the replay of UFC was airing), Adult (didn't matter which channel they are all lit up), and all the Premiums & Locals. I turned on the DN 110, perfect. I turned on the DN 119, perfect. I turned on the Bell 91, it waited for picture which to me means it's changing keys, and then everything lit up as it does every night when I get home. I will keep a watch on it? Sincerely, |
New member Username: JdrocciLisle, Ont Ca Post Number: 6 Registered: Dec-06 | Dropping = no signal, no picture, nothing... Quality 0........... |
New member Username: JdrocciLisle, Ont Ca Post Number: 7 Registered: Dec-06 | My Echo 7 is not giving me nothing. Still dropping evry few mins.... Echo 6,8 is fine |
New member Username: JdrocciLisle, Ont Ca Post Number: 8 Registered: Dec-06 | Hello I have a 2700a Pansat, my echo 7 is dropping every 5-10mins. I turn it off twice and it appears again. In 5 mins it happens again, over and over. I repeat the steps and it continues to drop. Could someone tell me what is wrong. My Echo 6,8 is fine....... jr |
Gold Member Username: PrfrmnjPost Number: 1423 Registered: Oct-05 | Just so everyone knows the while Viewsat released pgm files today it was only to imporove in these areas: ( Main software upgrade ) - Local Channel - Some missing channel added - Channel Block - You can't see adult channels when you set maturity level. - Display Information of the Song in Live Radio Channel - Sleep Timer - Display Violence/Nu_dity/Language in R,NC-17,UR - Add Favorite List in Live - Channel Search with Channel Name in Theme - Channel Search in Live - Closed Caption On/Off in Live It had nothing to do with anything that may be going on as of right now and nothing is being said at their site. |
New member Username: Mike8137Watsonville, Ca Usa Post Number: 1 Registered: Jan-07 | can any one tell me where i can find all the instructions on how to download bins and files for a pansat 2500a |
Gold Member Username: PrfrmnjPost Number: 1426 Registered: Oct-05 | Miguel - They are all over the place. You need to do a little research and please don't Highjack the thread... |
Silver Member Username: EdenmanPost Number: 228 Registered: Aug-06 | My Boxes: VS Platinum OK except Plaboy and AOV CW 600S Premium, FLU (on 287 and 287t), 2500 clone and CS 4000 Clone all have scrambled channels (All p0rn and about 1/2 of PPV on BEV) |
Silver Member Username: HanzPost Number: 172 Registered: Oct-06 | I just made a call home and my daughter says everything is working fine on the pansat 2500 clone. But she can't test all the channels because the channel is fixed only to ESPN2 due to the Australian Open which I'm recording. |
Silver Member Username: Mc_sunnyPost Number: 973 Registered: Feb-06 | this is only for BEV so far. Dishnet hasn't been effected yet !!!! -MAP 57 is back. If you don't have plastic(rom102/103) or a veiwsat(FTA) your out of luck. Viewsat was coded for this MAP call.}} |
Gold Member Username: LklivesPost Number: 7154 Registered: Jan-06 | It appears that Bev and DN 61.5 are being targeted ...Viewsats and Sonicview are the ONLY 2 receivers that seem to be NOT affected..and its a map 57 issue, NOT a change in Bev provider to 904 as was stated by someone..remember that Viewsat and Sonicview are close and share info w coders, and Viewsat has already overcome this map 57 issue last ECM with the first released fix... |
Silver Member Username: HanzPost Number: 173 Registered: Oct-06 | LK, how's your Magnum Extremview reacting? Did it get hit? |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 121 Registered: Nov-06 | [link removed] [link removed] [link removed] Dish keys: Last: Jan 18 46:45 Key 00, 86: 0F E6 29 BE 9F EF 41 11 A4 C8 40 3A D3 A3 58 26 Key 01, 96: C6 3E 92 9C 14 C0 41 41 05 7A FC 35 A4 4D 0E 8A KEY 00 00: 0F E6 29 BE 9F EF 41 11 01: A4 C8 40 3A D3 A3 58 26 KEY 01 00: C6 3E 92 9C 14 C0 41 41 01: 05 7A FC 35 A4 4D 0E 8A [link removed] |
Silver Member Username: Mc_sunnyPost Number: 974 Registered: Feb-06 | lolz i think this thread is not for advertising or keys...Your at post number 121 u know better then that...so why don't we just stick on the topic dude |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 122 Registered: Nov-06 | Well we know that it has not yet been hit.. |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 348 Registered: Sep-06 | Here I have vewsat...working bev and DN 100% Pansat working DN 100%.....PORN, PPV, Locals everthing...Spanish Playboy even |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 125 Registered: Nov-06 | Okay so it will be hit by tommorow morning. |
Gold Member Username: PrfrmnjPost Number: 1429 Registered: Oct-05 | Okay guys. I'm at home now and status is as follows: Viewsat 100% Fortec 100% Pansat 3500 100% However this is only 110 & 119 DN, but they are working fine and it is 5:55pm (eastern time) |
Gold Member Username: NydasPost Number: 1258 Registered: Jun-06 | Pantec - Pansat clone - many Echo 3 (61.5W) channels not working. SET SETmax, TVASA, Zcine,ZeeTV. Not working. Zguj, Sahara B4U working. Echo 8.1 seems OK except for a few locals. |
Silver Member Username: JuanchoSuperior Lake, Northwestern... Canada Post Number: 383 Registered: Dec-06 | What are you smoking . that's funny, What else is going on.lol lol lol |
Gold Member Username: NydasPost Number: 1265 Registered: Jun-06 | C/P from a senior memeber at CCC. "Join Date: Sep 2005 Location: Toronto Posts: 1,021 Possible Map57 in Stream again! Well, of course we have had our fun lately. But, I believe there are some confirmed reports from sources that Map57 has been implemented on BEV. Look for Dish to follow suit. Two things are possibly happening here. Either BEV channels are moving to new provider (same as Sunday Ticket) or there is a REV update in the stream only for BEV now. I have read post where folks have lost VENus on their C00lsat 5000/6000 and decided to use their AUX card, and guess what, they came back in. Atemga's and other emulator type testing equipment are using map3b to work, and are black on certain channels. Look for more news as this week goes by. Hope you guys have your necessary equipment. Go dust off those card readers, get ready for IKS again, and of course the Viewsat will still be running hot(since last summer). Ok folks here is the scoop. It looks like BEV and DN both are starting to play some games on us today. I will break it down as I know it by provider so far BEV: Recent channel changes to Plyboy to the new providor index for NFL SUnday ticket seems to be expanding. Some Vu channels, Venus channels, and normal channels are making the switch today. So far VS and Pansat seem to be not affected by the changes, but Neusat, Captive Works, Skyview and C00lsat are. DN: Chuckie added a new provider id to his stream as well last night during the crazy key change some of us experienced, where they keys did not actually change. So far there I am missing about half of the international channels on 61.5, I would say look for more internationals to be hit later today. This so far has been affected on ALL stb's." |
Silver Member Username: JuanchoSuperior Lake, Northwestern... Canada Post Number: 384 Registered: Dec-06 | What I read was about the chinese smatched a old weather satellite today and debris could harm civilian and military satellite operations.that's causing communication problems,.Even the U.S Defense was unable to communicate with a experimental spy satellite.. |
Gold Member Username: LklivesPost Number: 7160 Registered: Jan-06 | ." This so far has been affected on ALL stb's." NOT TRUE!...go c/p paste from someone who actually knows something! Your info is 99& bogus all the time! |
Gold Member Username: NydasPost Number: 1268 Registered: Jun-06 | LK: Nobody ever posts a C/P of yours at any other site except your own. As i told you before, go and take your Citalopram, and ask your doctor to put you on a phenothiazine as well, or better still change to Lithium. That will get you better. |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 349 Registered: Sep-06 | "What I read was about the chinese smatched a old weather satellite today and debris could harm civilian and military satellite operations.that's causing communication problems,.Even the U.S Defense was unable to communicate with a experimental spy satellite.." if that story had anything to do with this "hit" all of us would be down......even the GREAT viewsat would not work if the sat's were hit in space LoL |
Silver Member Username: JuanchoSuperior Lake, Northwestern... Canada Post Number: 387 Registered: Dec-06 | I didn't said that the satellites were hit, , I said the chinese smached their own sat, and the debris are causing communication problems. I will laugh a last, the communication's problems just started. that's like a meteor shower. go to read at some informative site.I don't have any problem with any of my 5 receiver, 2 pansat2500 clone 1 2700, 1 DG and 1 VS |
Gold Member Username: LklivesPost Number: 7164 Registered: Jan-06 | nalin...were U born an azzhole or U just progreesively became one?..U've been doing FTA (and never did DSS) for 6 months ONLY, and U think U know something...LOL |
Bronze Member Username: Hoosier_daddyPost Number: 19 Registered: Dec-06 | Pansat 2500 clone with 286T on DN all is as it should be. With over a week with no key changes is it really a surprise that something would change? |
Bronze Member Username: Hoosier_daddyPost Number: 20 Registered: Dec-06 | with autoroll working I might add. I will enjoy for now and if it goes down it goes down...More than paid for my investment... |
Gold Member Username: LklivesPost Number: 7167 Registered: Jan-06 | There was a DN key change earlier today...how can all be well, unless your keys autorolled, and U don't know it! |
New member Username: Candy1Post Number: 6 Registered: Oct-06 | I HAVE NO STRENGTH IT SAIDS 0% UNLOCK CAN ANYONE TELL ME HOW TO UNLOCK I HAVE A PANSAT 2500A PLEASE. |
Bronze Member Username: Hoosier_daddyPost Number: 21 Registered: Dec-06 | They did autoroll I watched them roll.....turned it on just before I posted and rolled while on this site....Watching ESPN2 right now...PPV et al are all there... |
New member Username: FrancodemanPost Number: 5 Registered: Aug-06 | Don't know if this will help but I just changed the keys on cool sat 5000 and 6000 both bev a dish and it's all back. For some reason, my receivers did not auto pick up 1630 key change. Will watch until she goes black. Still testing Ariza xtreme |
New member Username: Candy1Post Number: 7 Registered: Oct-06 | please i need help with my signal. |
New member Username: FrancodemanPost Number: 6 Registered: Aug-06 | Whatever they sent down the stream, hit my DN SW switch. Burnt out. All LNB's showing 110 only. Climbed on the roof and changed the switch and now reading all correct. Your signal problem might be that... |
Bronze Member Username: Bugs5254Toronto, Ont Canada Post Number: 42 Registered: Jan-06 | i have a pansat 3000 my daughter turned on the receiver yesterday it has no picture on tv. looked at it all black you can see the guide, 0 quality and did say that there was no transponder. did all the scan nothing. if anybody can help me please how to fix this problem. |
Silver Member Username: Pannu16Post Number: 410 Registered: May-06 | It is map57!! |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 350 Registered: Sep-06 | anyone have any links to other sites with news about this....I can only find this discusion here |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 131 Registered: Nov-06 | [link removed] |
Gold Member Username: LklivesPost Number: 7171 Registered: Jan-06 | all sites are discussing map 57 and this ECM.. |
New member Username: Crazy416Post Number: 9 Registered: Jan-07 | so how long does anyone think it will take for a fix to come out? i hope it's not like last time when it took so long. |
New member Username: KhaloudiPost Number: 2 Registered: Jan-07 | does anyone know why my satellite say channel update then it deletes some channels? |
New member Username: KenbelkOntario Canada Post Number: 2 Registered: Nov-06 | I have a Pansat 2700a and as soon as I entered the new 00 key's for DN it lit back up. For about a month now I've been missing alot of ppv channels from the guide is there a reason for that anybody. |
Bronze Member Username: TraxxSwiftcurrent, Sask Canada Post Number: 56 Registered: Jul-06 | what are you people talking about have pansat 2500 not a clone and everything is working fine ppv,prn,movies etc etc etc. |
Bronze Member Username: PachacartierPost Number: 94 Registered: Nov-06 | LK MOTHER FUCCKER YOU THINBK U WANNA BE GOD IN HERE GO FUCKKKKKKKKKKKKK YOURSELFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AND GO HAVE A LIFE YOUR A HALF DEAD MAN. YOU CAN NOT GET IT UP. THERE IS NO ONE YOU CRITISIZED / SHUT THE FUCKKKKK UP THIS IS NOT YOUR FUCKKKKKKKKKKKKKKKKKKKKKING SITE FAGOTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT |
Gold Member Username: LklivesPost Number: 7181 Registered: Jan-06 | Pansats are OK for now, along with Viewsat and Sonicview.. Franco....DN did NOT burn up your disque swutch, thats impossible...just coincidence...it must have been ready to blow, thats all...they are only $7, keep a spare or 2, and weatherproof it in a tupperware container.. BTW....NEVER mess with switches and cables when RECEIVER is powered ON...unplug it first...if NOT, U will IMMEDIATELY blow a switch, and possibly a LNB.. |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 351 Registered: Sep-06 | Kh I NEVER let my receiver auto-update the transponders All I ever got from that was loss of channels. I instead do a new scan once a week to update all transponders |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 340 Registered: Nov-06 | well something tells me that we will get a fix for 61.5 after the worldcup well time to buy a viewsat lol |
Gold Member Username: LklivesPost Number: 7185 Registered: Jan-06 | This is NOT considered a Major ECM, since Viewsat already discovered the source code for this, during last ECM.... in a few days, I think all will be OK again..but remember Superbowl is in 2 weeks, so expect more obstacles .. |
Silver Member Username: Ars88P.I.M.P , Pakistani/In... Post Number: 341 Registered: Nov-06 | lol ya...hope they get a fix tho... |
Bronze Member Username: PachacartierPost Number: 97 Registered: Nov-06 | LK STOP GIVING INFORMATION THAT YOU DONR EVEN FUCKKKKKKKKKKKKKKKKING KNOW WHAT IT IS. |
Bronze Member Username: AdavePost Number: 38 Registered: Jun-06 | i have 2 receiver one is cools2t and pansat i never use pansat 2500a so which file is good for 2500a pansat my cools2t not working properly. |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 133 Registered: Nov-06 | more info on the ecm::: [link removed] [link removed] |
Bronze Member Username: AdavePost Number: 39 Registered: Jun-06 | which file is better for pansat2500a |
New member Username: FrancodemanPost Number: 7 Registered: Aug-06 | Hey LK, thanks for the heads up. I hear that these switches go from time to time. That must be it. I'll watch till they go black. FUN! |
Bronze Member Username: ZibrunoPost Number: 14 Registered: Sep-06 | Anybody out there loosing channels? *orn is all blacked out and some others channels. Anyone know what's happening? |
Gold Member Username: LklivesPost Number: 7193 Registered: Jan-06 | home boy...learn to read, then maybe U would know whats going on..its posted everywhere here! |
Silver Member Username: HanzPost Number: 175 Registered: Oct-06 | LK, how long would you presume it might be before channels on 110 and 119 start dropping off? I at least hope HBO West, Showtime West, and ESPN and ESPN2 will stay up until the end of the month. It's awful for tennis fans and boxing fans if these channels black out, especially with the Australian Open going on right now. |
Bronze Member Username: Eatfish111Post Number: 79 Registered: Dec-06 | In the past once the ecm has been introduced into the stream it takes a week or 2 to loose all channels. Should start seeing the ppv and the xxx plus the premium channels to drop off this weekend. |
Bronze Member Username: NijhersPost Number: 18 Registered: Jun-06 | all indian channels are not working 110 and 119 are still working 61.5 and 148 are black i have ariza700 its black since 7:00 pm 18/1/07 |
Bronze Member Username: Crazy416Post Number: 13 Registered: Jan-07 | anybody knows if there's a chance we'll get a fix before we lose all the channels? unlikely but is it possible? |
New member Username: ThegimmerPost Number: 3 Registered: Dec-06 | Running two CNX V1 boxes. With there new bin file that was release early today, all the blacked out channels are now back. Extreme View box still has blacked out channels, waiting fix... This is on 91 for BEV, DN on 110 wasn't hit to my knowledge |
Silver Member Username: Dude123Post Number: 854 Registered: Jul-06 | well it takes some time to get a fix so be patient and we will have the new fix out soon. |
Gold Member Username: NydasPost Number: 1291 Registered: Jun-06 | The problems on 61.5W (Echo 3) are suddenly over. I don't know why, but all channels are suddenly back |
Silver Member Username: Dude123Post Number: 855 Registered: Jul-06 | Nalin its been doing that since last night, the channels would disappear and then they would show up for a while and then disappear again. its doing the same thing with 91 and 148W aswell. |
Bronze Member Username: HvsPost Number: 16 Registered: Aug-06 | DN is back... Everything is working perfectly OK...with same setting we had yesterday. PPV, sports..everything is working suddenly OK |
Silver Member Username: HanzPost Number: 182 Registered: Oct-06 | Maybe they were just doing a test, to see if they could black out a few channels. Maybe they're readying up to deliver an atomic bomb through the airwaves and eradicating all satelites, FTAs, and dishes? That would be funny! |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 134 Registered: Nov-06 | Captiveworks released: [link removed] Skyview released: [link removed] others coming... |
New member Username: Ak100Post Number: 5 Registered: Dec-06 | I know I was losing channels on 61.5 on Pansat 2700 but a simple reset on the back of the box did the trick in bringing it back. Not sure if that's an isolated incident with me. |
Gold Member Username: PrfrmnjPost Number: 1436 Registered: Oct-05 | This only adds credibility to the "So Called" sat smashing! I originally didn't buy into it, but when I talked to a few buddies still on active duty working in intell apparently they were having problems with their equipment. Again, take that for what it's worth. I have no clue if it is true or not, but I'm going to dig into it a little and see what I find. |
Silver Member Username: Pannu16Post Number: 411 Registered: May-06 | wow how come is everything back!! DN loves playin these games!! |
Gold Member Username: LklivesPost Number: 7196 Registered: Jan-06 | Rumor is that DN was trying out another provider ID, a 2nd one.. |
Bronze Member Username: AllicPost Number: 83 Registered: Jan-05 | Well folks, it looks like Bev is using MAP57 calls again for Porrn, and Dishnet maybe testing it again on 61.5 and 148 on the foreign programming. If you have an aux card and wish to view these channels, now is the time to pull it out & dust it off (use at your own risk). Reports of Xtremeview and C00lsat working again using the aux card solution. Sonicview and Viewsat appear to be unaffected.. Some of the cardless emu's aren't emulating the card as well as others and MAP calls may not be included, thus channels are going down. If your setup is going down, please report it here. This is for BEV porrn or Dishnet 61.5 foreign programming only so far. |
Bronze Member Username: PsychmonsterChi town, Il USA Post Number: 56 Registered: Jul-06 | pansat 3500 here...all is well, except last week Pl_yboy was scrambled on Dish and Nim and still is..( if pla_boy can figure this out, can others be soon ahead?)...all other channels still go, except for the temporary searching mode that happens for approx 5 minutes every few days when DN juggles the codes.. |
Bronze Member Username: Bugs5254Toronto, Ont Canada Post Number: 43 Registered: Jan-06 | will there be a fix soon for map 57? |
New member Username: JdrocciLisle, Ont Ca Post Number: 9 Registered: Dec-06 | I still can't get Echo 7 going, now it's not even going on when I switch the back button. Can somebody give me some advice of some digits I should be looking at or something. I have a pansat 2700A clone I believe......... |
Bronze Member Username: PsychmonsterChi town, Il USA Post Number: 57 Registered: Jul-06 | IF DN is still screwing around with Map 57 or a derivative, its because they have do not have the budget or technology to counter the fix already in place, they have spent millions only to be thwarted from leakers inside thier own industry selling to VS and eventually all boxes..They knocked down subscribers running older IRD's at first, and had to pull it out of the stream because / or they are working on a better ECM that will knock down not only all FTA, but the 102 systems and card hacked systems....so far our luck has held, the programmers at DN so far are impotent...!!! |
Silver Member Username: CanndyWww.livefta.com, Www.livefta.com Www.livefta.com Post Number: 137 Registered: Nov-06 | Pansat and other fixes released: [link removed] not for clones. Clonse-safe bin will be released soon. |
Gold Member Username: PrfrmnjPost Number: 1445 Registered: Oct-05 | And I ask - Why would anyone want to get files for third parties when they can get them from the originator from their home pages. For Pansat files go to FutureFTA For Viewsat file go to totalFTA But if you absolutely need to go elsewhere for a file, then go to the list of Reputable DSS Sites and pick a site there. My recommendations (besides the above): DSSCommunity DSSTesters Al7bar While Al7bar will be questioned, I've worked with them for some time now and I have no problems endorsing that site. |
New member Username: JdrocciLisle, Ont Ca Post Number: 10 Registered: Dec-06 | For Pansat Files go where? FutureFta brings me to a hometheater site, have one already......... |
Gold Member Username: NydasPost Number: 1296 Registered: Jun-06 | Jamie: futurefta site URL is as follows: To enter the site, you will have to click on the logo at the top. Just for your information, it is considered the official site for latest information on Pansat. You will also get information on other satellites there. It is not he same as which is the official Pansat site. |
Gold Member Username: NydasPost Number: 1297 Registered: Jun-06 | PRFRMNJ : There is a lot of FTA sites and I would say most of them are reputable. Even dsstester*com which has been much maligned is essentially clean. What happens now and then, is that somebody posts a bad BIN at a site and it gets unnoticed for long enough for the site to acquire a bad name. |
Gold Member Username: LklivesPost Number: 7208 Registered: Jan-06 | Many of the coders themselves (Blacklist, Sager,Chancy, Don dinero, thadeadman etc) will actually post their files DIRECTLY at Dsscommunity and Dsscentral...remember dsscomunity/dsscentral has original owners and longest site on the net, and has many contacts and friends in DSS.. |
Gold Member Username: PrfrmnjPost Number: 1447 Registered: Oct-05 | Nalin - I know that and DSS Testers has always been a good resource for me. But I can only recommend those sites I download from and have hands on experience. I normally go to DSS Testers not for files, but for information. And that they are very good at. The last thing I want to do is tell someone download from here and next thing you know their receiver is dead. I make it a point to download from a long list of sites and test the files myself before recommneding it. I am a member at so many sites I can't keep track of them anymore, but one thing is for sure, if I have a bad file from any of the sites listed as Reputable, I will be the first one to notify everyone to stay away. That however, has not happened. |
Gold Member Username: PrfrmnjPost Number: 1448 Registered: Oct-05 | Naling - BTW you are right. Pansatusa is the official site for original Pansat original files and loaders, so let me clarify my statement: The coders for Pansat post their files directly to FutureFTA. DSS Community/DSS Central also get their files from the coders themselves. The beauty of DSS Community is that the have pretty much all the coders posting there, rather then just one coder. |
New member Username: ShnPost Number: 6 Registered: Nov-06 | where can i find auto roll extreme viewsat software? |
Gold Member Username: NydasPost Number: 1374 Registered: Jun-06 | sharon wells: Go to [link removed] |
Silver Member Username: Ke5aqnShawnee, OK USA Post Number: 479 Registered: Sep-06 | thanks nalin we missed her question on this thread. Sure wish they would start a new thread. |
Gold Member Username: NydasPost Number: 1376 Registered: Jun-06 | Jay: Keep up the good work and don't get irritated by newbie questions. You have a lot to give. |
