Bronze Member Username: TinytunesPost Number: 30 Registered: Sep-06 | I have a bell dish with to dishnet lnb's i can only get 110 but not 119 can someone help me i'm using a pansat .Thank you | |
Gold Member Username: PrfrmnjPost Number: 1903 Registered: Oct-05 | Need more information then what you've provided. What is you setup? are you running switches? What type LNBs? As much information you can provide... | |
Bronze Member Username: TinytunesPost Number: 32 Registered: Sep-06 | Yes i have a switch the LNB's say dishnet dule. | |
Gold Member Username: PrfrmnjPost Number: 1908 Registered: Oct-05 | You're not making this easy. WHAT is your setup? Are the LNB's DISH PRO Twin/Quad or DISH PRO PLUS. Whar receiver? What is your antena setup. Would you go to the doctor and say I'm in pain or give him a description of what the pain is and where its located? |
Bronze Member Username: TinytunesPost Number: 33 Registered: Sep-06 | The LNB's are single dishnet with to port that all i no on them my' antena what should my ant setup be it is a pansat 3000 does this help. | |
Bronze Member Username: TinytunesPost Number: 34 Registered: Sep-06 | What do thy mean buy 119 as default like i sad i get 110 and i found it first and than tried 119 and got 0 quality. | |
New member Username: AcuraPost Number: 2 Registered: Feb-07 | what are you doing! it's illegal! | |
Gold Member Username: PrfrmnjPost Number: 1910 Registered: Oct-05 | Pay no mind to ACURA. Are both LNB's on the same dish? How is the dish setup? What switch are you using? Is it pointing in the right direction? If you give me your zip code I will give you the correct angles for your dish. | |
Bronze Member Username: TinytunesPost Number: 35 Registered: Sep-06 | I've got the right angles disq 1 is set for 110 disq 2 is set for 119. | |
Bronze Member Username: TinytunesPost Number: 36 Registered: Sep-06 | Could it be tree's in the way. | |
Gold Member Username: PrfrmnjPost Number: 1914 Registered: Oct-05 | Is that the way the LNB's are connected to your Switch? Normally 119 should be connected to 1 and 110 to 2. Make sure you verify this on your antena configuration. Remember that the first TP on 119 normally does not have signal. | |
Bronze Member Username: TinytunesPost Number: 37 Registered: Sep-06 | Yes i do no that 119 is on tp2 and 110 is tp1 should i try to get 119 first.
Gold Member Username: PrfrmnjPost Number: 1916 Registered: Oct-05 | It really shouldn't matter, but because it is the further one it will not hurt. | |
Bronze Member Username: TinytunesPost Number: 39 Registered: Sep-06 | Should i do a reset on my pansat and then try. |
