Hi Can somebody please help me in adding a channel in Pansat2700A manually. How many times I do satellite scan, the channel 457 and 471 is not being scaned. I have these settings, how do I add those..
Hey Achsah Channel 457 is on EchoStar 8/10 at 110.oW PPv Sports Freq. 12239 (Pol.H) SR 20,000 (tp2) also on the same TP, Dish Network PPv Channel 517.
There is also a PPv Sports Channel 461 at EchoStar 8/10 Freq. 12443 (Pol.H) SR 20,000 (tp16). I couldn't find Channel 471 or Freq. 13362 on EchoStar 8/10. Channel 471 PPv Sports is located at EchoStar 1/2 @ 148.oW. Just do a TP Scan for the above TPs.
As pointed out by Kevin above - Do a TP Scan of those transponders and you will get those channels. In the event you are not getting a signal from there, you will need to verify the alignment of your antena.
Hi I am having the same problem. I did all kind of scan, but I am not getting channel 457 and 471.
Achsah...let me know if you are getting the channel? and what exactly you did to get those channels. Please post step by step instructoin as I am new to this.
go to http://www.future-fta.info/Forums/ find the section for your receiver and get the latest .bin for your receiver. That is the home for pansat the people that make the bin files are their all other sites have copy's of it. Its always best to go straight to the source.
I am still not getting channels 457 and 471. I did the blind scan and I also changed the keys. I am on satelite 110. It's still not working. Any help is appreciated.
Antenna settings are correct because this was professionlly installed bY dish network people. Do I need to change the DiSEqC or TP on the antenna set-up screen?
