A few questions about my speaker setup....
Username: As007
I started out with the Focal K2P component set, now I have replaced the Focal mids with the Morel Elate 6 SW's. I am still using the focal crossover and was using the tn52 tweeters but one of them went bad, so now I am looking for a new set of tweeters and came across the Morel Supremo tweeters.. so I am wondering how those morel tweeters and morel mids would sound using the focal crossover? Does morel sell just crossovers, if so which one would you suggest me using with this setup? Or would it just be best to leave the focal crossovers and just buy another set of focal tn52's...?
Username: Warlok
Orlando, FL USA
Post Number: 133
I personally would go Morel x-overs. Although, I dont think it would damage anything so as long as the x-overs had the same low pass cutt off. More than likely the High pass will be fine. Get some more opinions, Ive never mixed and matched X-overs before.
