Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 916 Registered: Jul-06 | Does anyone know where I can find a crimper for 0gauge and bigger wire terminals?I've seen some as low as 60 bucks but it didn't look too great.I've also seen the Greenlee ones for 200+ which also isn't that appealing lol...I was just wondering if anyone here knew where to get a good one for a decent price,thanks. |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1969 Registered: Apr-06 | screw crimpers..... give these a try, they work great. http://cgi.ebay.com/2-GOLD-PLATED-RING-TERMINAL-0-GAUGE-5-16-HOLE-PST0G_W0QQitem Z140073365442QQihZ004QQcategoryZ32809QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 921 Registered: Jul-06 | That's what I'm using right now lol.I was actually going to mention that I was using terminals with set screws to avoid a post like that lol...but oh well.I want to have a crimper as well because sometimes people don't want to pay the extra money for the more expensive ring terminals such as the ones you showed me I do reccomend using the terminals with the set screws as well because you don't have to chop up your wire when you want to remove them. |
Silver Member Username: Zoomiebird15 Wanger Premier Member, FL Post Number: 348 Registered: May-06 | solder and never remove. |
Gold Member Username: Mr_keboAlbertville, Al USA Post Number: 1197 Registered: Nov-04 | yep solder is the best way. |
Gold Member Username: BestmankindWww.15inchwangers.comFI Audio BTL Post Number: 9673 Registered: Oct-05 | i use hammer. |
