What is the best way to clean up my channels and repeats
Username: Book77
Post Number: 26
I was wondering what is the best and safeiest way to clean up my channels.
I have so many repeats and improper names on channels .
Is it best to factory default - channels delete
I have a Captive Works 600S
Username: Crazy_greek
Post Number: 486
Just do a Factory Setting.
Input your Longitude and Latitude.
And then do a Blind Scan on each Bird.
Username: Brucester
Post Number: 161
i have cw600p and i do it by factory default then i pic the sat for me 91w bev then i do a blind scan when dun exit hit the patch(f1 000give it sum time it will roll hop this helps
Username: Prfrmnj
Post Number: 1616
The easiest way to do a successful blind scan and avoid repeats is to turn off the lnb power to the sat you are not scanning and then scan the other one. Example:
Scanning 110
Turn off LNB Power to 119
Scanning 119
Turn off LNB Power to 110
Depending on the receiver you may have the option to turn the LNB Power off, but it will give you the option to deselect sats. So follow the above only deselecting the sat you are not scanning.
