Ring Terminal Crimpers?
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 915
Does anyone know where I can find a crimper for 0gauge and bigger wire terminals?I've seen some as low as 60 bucks but it didn't look too great.I've also seen the Greenlee ones for 200+ which also isn't that appealing lol...I was just wondering if anyone here knew where to get a good one for a decent price,thanks.
Www.15inchwangers.comFI Audio BTL
Post Number: 9674
double thread FTW
Username: Tremor1127
Wishes there was an 18...
Post Number: 726
solder FTW...
maybe try a welding supply company...
Post Number: 9675
tremor is right FTW.
i also like to use hammer.
Username: Rovin
1 12 Atomic ...
Post Number: 10507
use a vice grip or better yet a good bench vice ......
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3634
^^^yup. i use a bench vise.
Username: Th3pwn3r
Post Number: 924
Using a vice and a hammer are not very solid ways of putting a ring terminal on.I've tried both of those methods for a while but they aren't the best.I can pull a ring terminal off that was been vise clamped or hammered on with my bare hands,I've done it.It holds but it's not very solid.Using an actual crimper is actually the best way but they run from 60 bucks for a tap type of set up and then 200 on up for the actual crimpers that I asked about.Thanks for staying on topic guys :-(
Username: Th3pwn3r
Post Number: 925
http://www.toolup.com/productinfo.asp?ID=K09-3GL&Man=Greenlee&pid={7952E75A-D4AF-470D-B905-4AFAA85AB800}
I've applied ring terminals all sorts of ways but that's the best way to put on a ring terminal,however, the cost sucks.
Post Number: 3638
a bench vise WILL NOT pull loose lol.
Username: Th3pwn3r
Post Number: 926
It won't?Damn...I guess I just made up a lie randomly.
Post Number: 3642
do you know what a bench vise is? those things can apply hundreds of pounds of pressure. all you have to do is know how to put on the ring terminal... you obviously dont just smush it. use pliers to bend in one side into the strands of wire, then the other. now smash them together.... it wont pull, not with your hands anyways, unless your chuck norris.
and so yes, that was NOT a fact what you said and it wasnt random because it was on topic. so please stop bein a d!ck. thanks.
Username: Drivingreckless
DD 9515f, USA
Post Number: 2729
hhahaaaha
rob=d*ck
trevor=a**hole
so the d*ck f*cks the a**hole
so i guess rob wins???
Post Number: 3644
nah see i was trying to help. hes the one with the problem. i can use my bench vise all day to crimp 0awg. so i win.
DD 9515f, USA
Post Number: 2731
hey trevor
y dont u go to the competition in
aurburndale on sunday????
thiers a bunch of ppl from
Realmofexcursion.com goin
its only an 1hr from tampa near plant city
Post Number: 3647
really?... you got any other information on it? I'll go as long as I dont have anything else to do on that day.
DD 9515f, USA
Post Number: 2733
http://www.floridaspl.com/forum/viewtopic.php?t=511
join tht website its got all the latest events
up to date
Post Number: 3648
i found info on it.... whats it cost to get in if your not competeing? cause obviously I'm not going to be ready to compete by sunday.
DD 9515f, USA
Post Number: 2735
its free to watch lol
u only pay if u compete
also if u do go ill be the oone with
the green xterra with
1 9515 and a kicker kx2500
im hispanic 6'1" 170 lbs u cant miss me bro
plus ill be loud ;]
Post Number: 3649
lol aright ... I'll try to go. it's 1 hour 39 minutes from me. ima see if my friend with 2 DD 3515s wants to go. look down a tad, I'm 5'8" 135 lbs lol. black escalade on 4s which there will probably be more then one there lol. I'm the one NOT bumpin lol
Username: Th3pwn3r
Post Number: 927
I'll be a d1ck for as long as I please but only to a select few people.Have you ever used an crimper like the one I posted Trevor?If you had actually used one in an install shop you would know why I want one for myself.The time you save is also valuable as well.By the way you weren't helping me at all...I never asked how to crimp a ring terminal onto a wire,I asked if anyone knew where to get a crimper for a decent price,so thanks for the useless posts Trevor :-( With all hostility aside now,how are thoses mags doing?I highly doubt they sound "Muddy" as some members on here have said.
DD 9515f, USA
Post Number: 2737
ive herd a mag b4 rob
they sound excelent compared to every thing else ive herd
and also are efficient
but my DD will take it to the house
Post Number: 3650
they are chillin right here beside me right now. ive been smoothing out the interior of the box. i hope thats done soon. my friends suposed to give me the grand he owed me tomorrow so im going to order all the wires and stuff i need to complete everything so i hope by feb 10th I'll be done with it all....well i wont have my HO alt yet...
btw... cant tell how big this one is but...
http://cgi.ebay.com/NICOPRESS-53-XPJ-TELEPHONE-WIRE-CRIMPER-OVAL-HEAD_W0QQitemZ2 00070946732QQihZ010QQcategoryZ11704QQrdZ1QQcmdZViewItem
this one LOOKS like a beast
http://cgi.ebay.com/WIRE-CABLE-CRIMPER-CUTTER-RAJAH-VINTAGE_W0QQitemZ13007013609 4QQihZ003QQcategoryZ20767QQrdZ1QQcmdZViewItem
i dont know what this really is but "can do" 4/0
http://cgi.ebay.com/ebaymotors/Battery-Terminal-Welding-Lead-Terminal-Crimper_W0 QQcmdZViewItemQQcategoryZ35625QQihZ006QQitemZ160075348273QQrdZ1QQsspagenameZWDVW
confused on this one as well...
http://cgi.ebay.com/HeavyDuty-1-25-to-14-mm-large-Terminal-Crimp-Crimper_W0QQite mZ170062573982QQihZ007QQcategoryZ66987QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
DD 9515f, USA
Post Number: 2738
lol feburary tenth is a free meterin in oldsmar.T & J eleite customs
so trevor if u finish
come thru
its starts around 6 but ppl wont show till 700
Post Number: 3652
i have no idea where oldsmar is but i can find out. my friend was tellin me he thinks on feb 10th is a comp or show in tampa that you can find on tampa racing or something .com lol and he knows the guy so he can get TL access whenever there for free.
DD 9515f, USA
Post Number: 2739
yea oldsmar is a part of tampa
its free TL
its called T & J elite customs
off of
101 pine ave
oldsmar, fl
its 10 mins from my house
Username: Th3pwn3r
Post Number: 928
Trevor the one on the third link is used with a hammer :-) I might give one of those a try.Thanks for the links.
