well im looking for a new car as we all know. i have bought everything for my sytem as we all know too. i bought everything thinking it would go in my tc i have now but gettting rid of now. i want to get a wrx and they have 4" speakers in the front. i bought 6.5 comp for up front of my car. i was wondering if they is something i can buy/make maybe where the 6.5 comp can fit in the 4" speaker place in the wrx.
it kinda depends, but try putting an MDF baffel over it and it might bring the speaker out enough so some of it will fit in the 4" hole. if not you could cut the hole bigger with a dremmel tool or somehting
yeah your best bet is cutting a mdf ring to fit the 6.5s n see if they will drop in there. or if your really determined make fiberglass door panels like i did.
