i have a PG RSd 1200.1 mono amp and i was thinking about getting two subs, but when i look at the amp, there is only one set of positve and negative connectors. Does this mean i cant run two subs to this amp and only one? Are mono amps meant for only one subs? (hence the word mono)Sorry but i just dont want to end up buying something i cant return so I have to know.
The answer to your question about "mono" is NO. You can run more than one sub on a Mono amp. Just in case you couldn't figure that out by Optidriven's posts
