Powering 12" fi q's
Username: Nitrofour
Post Number: 18
I want to power two 12" fi q's, is a Kicker ZX 1000.1 for each one a good idea? What ohm should i get for the q's and is that just the right power? Or should these be run lower?
Username: Ctmike
Ct.
Post Number: 3078
that'd be a good match. with those amps get dual 1ohm subs.
Username: Nitrofour
Post Number: 20
thanks ctmike, and would you recommend the 12" fi q's over the 12" idmax's for SQL?
Username: Ctmike
Ct.
Post Number: 3079
i'd give it to the q.
Username: Matt12490
The biggity biggity BAY, California USA
Post Number: 1558
or you can do like me (planning to do)
2 dual 2ohm and a sundown 1500d @ .5ohm
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4015
2 amps will flow more current.
