Username: Rosrock2000 Notre dame!USA
Post Number: 204 Registered: Dec-06
Tuesday, January 23, 2007 - 20:10 GMT i have money to by a q or bl(im gonna do copper coil I think). Ill be putting 1100 at 1 ohm to it. tell me what u think
Username: Ctmike Ct.
Post Number: 3042 Registered: Feb-06
Tuesday, January 23, 2007 - 20:12 GMT depends what you want, more sq or spl. haven't heard the bl but i have heard the q, sealed, and it sounds amazing and gets really loud for a sq sub.
Username: Nkknutson Post Number: 50 Registered: Dec-06
Tuesday, January 23, 2007 - 20:24 GMT what do you think about a 12" or 15". is there a big difference. i want to buy on but don't know which one to get? i like rap, but once in awhile will listen to everything else.
Username: Nyyfan13 Fi SSD
Post Number: 2763 Registered: Jul-06
Tuesday, January 23, 2007 - 20:25 GMT bl is more spl ive heard q is more sql and my ssd is just awesome...lol
Post Number: 3044 Registered: Feb-06
Tuesday, January 23, 2007 - 20:30 GMT 15" will get lower. really depends on what you want and the room you have to spare.
Username: Nkknutson Post Number: 51 Registered: Dec-06
Tuesday, January 23, 2007 - 20:32 GMT i heard anything bigger than a 12" is only good for rap. any truth to this
Post Number: 207 Registered: Dec-06
Tuesday, January 23, 2007 - 20:33 GMT is it just me or does EVERYONE on here love fi? it should be called ecousticsfilovers.com
Post Number: 3045 Registered: Feb-06
Tuesday, January 23, 2007 - 20:35 GMT wait till you hear your q and you'll see why
Username: Livin_loud 18 of Love Fi Audio
Post Number: 905 Registered: Jan-06
Tuesday, January 23, 2007 - 21:54 GMT ^^^^^^^^ agreed
Username: Tdeaton1021 Near Tampa,
Florida
Post Number: 3639 Registered: Sep-04
Tuesday, January 23, 2007 - 23:08 GMT you could use a 18 for rock, jazz, classical, emo, whatever lol
Username: Trey4sports Post Number: 344 Registered: Sep-06
Tuesday, January 23, 2007 - 23:41 GMT typically, the bigger the sub the lower it resonates naturally and hits lower notes better but some subs especially from underground brands like Fi and RE will stay crisp and not get sloppy like most cheap subs.
Username: Nkknutson Post Number: 52 Registered: Dec-06
Wednesday, January 24, 2007 - 00:32 GMT ok i'm sold on the FI Q15" when i build the box how many inches do i need from the sub to edge. I was thinking 1.5" or 2" so my height was going to be 18" to 19" is that ok?
Post Number: 910 Registered: Jan-06
Wednesday, January 24, 2007 - 00:51 GMT as long as you don't screw it into the sidewalls i believe its fine...
