Polo - 3.8 supercharged with 300a HO alt?
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 4115
hey man, trying to verify this has been done... i need a quick answer. my boi has the 3.8 series 2 supercharged in his park avenue ultra. and both dom and nate said they can only do a 200a max....
please chime in POLO..
Username: B101
Post Number: 4124
Username: Nickb4247
Post Number: 68
Is there any way to do two alts?
Username: Nickb4247
Post Number: 69
Or would that require to much machining?
Username: Cenus
Hicksville, Ohio
Post Number: 2819
ya you can do 2 alts, my friend has it done on his mustang.
Username: Safe_cracker
Chicago, IL US
Post Number: 2367
SORYY, YES!!! Iraggi has a Bosch unit for that engine it is a special order and it costs but is worth it. Polo..
Chicago, IL US
Post Number: 2368
It is the "amputator series" has a smaller pully pulls like 220A at idle 300+A at 2000 rpms, something like that.Totally different case that is where everyone else is having problems, they are using the factory cases and rebuilding them. Polo.. :-)
Username: B101
Post Number: 4125
ohh, I see, thanks for clearing that up... how much was the amputator series?
here is a pic of the engine.
Username: B101
Post Number: 4128
Polo, did u remove your SC? turbo??? :-)
Username: Alexv305
Tavernier, FL USA
Post Number: 550
how much can treo SSX 15s take daily... i know they take more then 2500w RMS... polo u know?
Username: B101
Post Number: 4134
daily people has given them as much as 4krms with moderation, checking the temp, leting it cool etc...
I know the 18 SSX can stomp on 6krms daily, cause a girl had this setup.
safely, they should eat 3-3500krms easily!
I mean, I had 2500rms per each 500rms TSX, so big brother SSX, will have no problemo!
Chicago, IL US
Post Number: 2378
B, no there is no need to remove the supercharger to put it in. Get a 15mm box end on the tensioneer pulley releasing the spring causing the belt to go slack. remove the belt off that pulley then let it hang.Unbolt it and reinstall the new no need to even change the belt. I think it was $480. Polo.
Username: B101
Post Number: 4151
ok, i should get it in pretty easy. I got to send me other 300A for my 3.8 to get recased for my burban. maybe add a external regulator also.
i was asking about the SC, cause ur pic, almost looks like it is capped off.
