Gold Member Username: J_baby15Kentucky Post Number: 1165 Registered: Feb-06 | where could i find sum descent plate amps? Im plannin on buildin a subwoofer cabinet for in home use, usin a car sub. I want sumthin that does around 1000+ rms. Any ideas? What are most home sub boxes tuned to? |
Gold Member Username: HawkHighlands Ranch, CO USA Post Number: 1079 Registered: Dec-03 | Check here: http://www.partsexpress.com/webpage.cfm?Webpage_ID=3&CAT_ID=43&ObjectGroup_ID=50 5 Good luck! |
Gold Member Username: J_baby15Kentucky Post Number: 1166 Registered: Feb-06 | one problem. the sub ive got now is dual 4ohm. so id be runnin it at possibly 8ohm or 2ohm. do they make 2ohm stable plate amps? The biggest one on there did 1000 at 4ohm. Of course i could always do 2 12s and then use that. Which do you think would be better(its for a home studio/recording purposes), 1 15" or 2 12s? |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 4834 Registered: Feb-06 | 2 12's |
