Gold Member Username: Blainew
Alpine type S 6.5 inch...
Post Number: 2109 Registered: Nov-05
Posted on what setup...... or...whats a better 12 setup two or one i dont care, but i want 1000 watts total, 1 or 2 ohms total i dont care |
Gold Member Username: Southernrebel
Monroe,
Louisiana
DD 9515d~~]...
Post Number: 4069 Registered: Mar-04
Posted on 2 12" R's |
Post Number: 2110 Registered: Nov-05
Posted on thats what i thought will 2 12's generaly be better than 1 12 of the same brand... even if both have the same total watts |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 11130 Registered: Jul-05
Posted on ^^^yep |
Gold Member Username: Bestmankind
Www.15inchwangers.comFI Audio BTL
Post Number: 9543 Registered: Oct-05
Posted on used them both and the 2 type r's would destroy that single type x. infact a single type r can get just as loud as a single type x. btw the type x isn't much better on sq either. |
Gold Member Username: Bernymac
Cambodian
Post Number: 1805 Registered: Sep-04
Posted on type R's ftw. |
Post Number: 9544 Registered: Oct-05
Posted on berny stop posting in the forum and get the website done. lol. |
Post Number: 2111 Registered: Nov-05
Posted on i need to get my hands on some of those old diamond cm3's....the ones with the red moons |
Gold Member Username: Tdeaton1021
Near Tampa,
Florida
Post Number: 3559 Registered: Sep-04
Posted on i was giong to say type Rs but i think you got the point lol |
Post Number: 2112 Registered: Nov-05
Posted on hahah yeah |
