Rattttttttle!!!!!!!!!!!!!!
Username: Greenneon
York, PA Unites State...
alright i got a 2000 ford taurus SE with 2 12' JL audio subs and a 500 Watt JL audio amp. my truck rattles uncontrolably. i cant hear it from the inside but u can hear it from the outside... how do i make it go away?
Username: Tdawg30
Ohio USA
Post Number: 915
its called sound deadener..........google it.
Username: Basshead86
FTW
Post Number: 9910
step #1: www.google.com
Username: Tdawg30
Ohio USA
Post Number: 917
I had Muddy in mind when I posted that. shoulda quoted you though man. sorry
Muddy: "google it"
GOOGLE FTW
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 160
dynamat
http://www.dynamat.com/products_car_audio_introduction.html
Username: Greenneon
i tryed dynamat and it didnt help at all i bought the full trunk kit and it still rattles like hell
Username: Tdawg30
Ohio USA
Post Number: 919
you got to put that stuff everywhere man. dont buy more dynamat. go here and get this stuff at the discounted price while you wtill can. the deal ends sometime in feb so get it quick. just like dynamat, but way cheaper. (edead V1^2)
http://www.edesignaudio.com/edv2/advanced_search_result.php?keywords=forum
Username: Tanmanfosho
Fi SSD, 15 Wangers Yeah, Its 15...
Post Number: 565
then u didnt do it right cause 500 watts isnt a lot.
Username: Greenneon
i heard if i rino line my truck the rattle will go away ... is that true?
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 4824
rino?
Username: Greenneon
rhino line... the stuff u spray on for beds of a truck
Post Number: 4825
no way in hell i would do that. http://www.edesignaudio.com/edv2/index.php?cPath=24
Username: Colem
Post Number: 8
I dunno, i have 60 feet of e-dead and 20 feet of somthing else and it still doesnt stop my l7 from trunk rattle
Www.15inchwangers.comFI Audio BTL
Post Number: 9598
it appears that you need to tightened things down a little. try to do something to make your trunk close tighter. also check your tail lights. maybe the bass broke something inside.
