99-07 Gmc/Chevy Extended cab Trucks
Username: Mr_kebo
Albertville, Al USA
Post Number: 1180
Anyone drive one and still have the rear seats in. I need someone to measure for me that max size a box could be to fit under there. Im looking to build something like this for my buddy thats in iraq and his truck is in storage and i cant measure it.
http://img516.imageshack.us/img516/1841/dscf0137fd1.jpg
http://img241.imageshack.us/img241/9580/dscf0138gh8.jpg
Its gonna be for a fully loaded 12" BL from FI. He was running a 12" MAG in it and said it didnt hit the bottom of the seat when it was down. the top it double baffled to help flush mount it. He said its 2.0tuned to 33hz. I want to tune to around 35hz or so for my buddy.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1434
Outside dimmensions are;
7" back
9.5" front
14" deep
57.5" - 58" wide
the gap in the center is about 15.5"
Username: Mr_kebo
Albertville, Al USA
Post Number: 1181
how tall in the gap in the center?
Username: Mr_kebo
Albertville, Al USA
Post Number: 1182
i need to see how this is gonna work out lol and be like he said. I may have to lift his rear seats up 2"
Orangevale, Ca. USA
Post Number: 1435
3.5"
Username: Mr_kebo
Albertville, Al USA
Post Number: 1183
i wish he would msg me back so i get get the dimensions of the box he built.
Username: Mr_kebo
Albertville, Al USA
Post Number: 1184
I just ordered the brackets to lift the rear bench up 3"
Orangevale, Ca. USA
Post Number: 1437
Whats your dimmensions so far?
How much volume do you hvae in CF or liters?
Username: Mr_kebo
Albertville, Al USA
Post Number: 1185
i dont know thats why i asked. I cant get to the truck its in storage while he is in iraq. I just added 3" to what you gave me so i will be good im sure. lets do some figuring to see what i get and what you get. Im gonna do 10" For the height all around.
Username: Mr_kebo
Albertville, Al USA
Post Number: 1186
i figure 2.968 internal dimensions. ive never done pvc ports so i dont know how to figure them yet. need to tune this enclosure to around 35hz or so.
Orangevale, Ca. USA
Post Number: 1438
What type of wood are you going to use? MDF? What thickness?
Username: Mr_kebo
Albertville, Al USA
Post Number: 1187
3/4 MDF. I will need to double baffle to top piece so i can flush mount the sub some. I actually need to do about 9" on the height and double baffle to keep the sub away from the bottome of the seat.
Orangevale, Ca. USA
Post Number: 1439
If you use the outside dimmensions of 10 X 57.5 X 14, and use 3/4" thick wood, your inside dimmensions are 8.5 X 56 X 12.5 = 5950
The center cutout outside dimmensions are 3.5 X 15.5, so your inside dimmensions would be 4.25 X 17 = 72.25
Now subtract 5950 - 72.25 = 5877.75
Now divide 5877.75 / 1758 = 3.34343 CF*
You still need to subtract driver and port displacement. I do not have BassBoxPro6 on the comp I have now, otherwise I would help you. Ask arround and see what you need.
Username: Mr_kebo
Albertville, Al USA
Post Number: 1188
http://www.supercrewsound.com/shop/index.php?cmd=pic&mod=11&id=192a looking at that thats 2.6cuft total using 5/8. I wish i could get to this freaking truck to maybe i could design a box for this freaing 12" sub. Downfiring would be great.
Username: Extrmndor3
Sit and Look pretty
Post Number: 3285
man Mr kebo coronas are the finest beers cuz they come from mexico and are made in mexico by mexicans that gives the coronas authentic mexican flavor.
try to get "mezcal" its likea tequila made out of worms they even include inside the liquid a worm that u eat that shyt taste great but i havent ate the worm in my life but alot of people do and they luv it :-)
try "jarritos", "manzanita" "sangria" those are some good sodas
this shyt was refreshing
Username: Mr_kebo
Albertville, Al USA
Post Number: 1189
ok thanks.
Orangevale, Ca. USA
Post Number: 1440
For 9 X 57.5 X 14 OD, its 6.75 X 56 X 12.5 ID = 4725
4725 - 72.25 = 4652.75
4652.75 / 1758 = 2.6466154 CF
Username: Mr_kebo
Albertville, Al USA
Post Number: 1190
this can be done. I know it lol
Orangevale, Ca. USA
Post Number: 1441
Im guessing that the only way the supercrewsound can get 2.6 CF is if they use 5/8" thickness and slant the box from 9" front to 7" back.
My configurations above are all using 3/4" thickness, and no slant, just squared up like you said.
Orangevale, Ca. USA
Post Number: 1442
You can do it !!!
FTW :-)
Username: Mr_kebo
Albertville, Al USA
Post Number: 1191
yea i guess i could slant it.
Orangevale, Ca. USA
Post Number: 1443
Be carefull with your design.
The slant only offers you the option to get away from rasing the seat. You need to design it so that the woofer doesnt bottom out.
I have an 02 GMC Sierra extended cab and I built two separate boxes instead of one with a cutout for the center hump. I have one 8" firing forward in each box, so thats why I was able to use the entire space. If you wanna do a 12", you cant install it firing forward, you have to install it on top, bottom, or slanted at the end. Each design has its complications and limitations.
Be smart. Measure twice, and cut once. :-)
Username: Mr_kebo
Albertville, Al USA
Post Number: 1193
http://img440.imageshack.us/img440/5799/box11gn.jpg
http://img212.imageshack.us/img212/595/box20ff.jpg
He sent me that and said it works just fine with the seat down
Username: Mr_kebo
Albertville, Al USA
Post Number: 1194
not raised in his 03 sierra
Orangevale, Ca. USA
Post Number: 1446
You know, at midnight my time, I guess I was too wore out, and I miscalculated.
If you look above where I made the 4.25 X 17 = 72.25, I forgot to include the third measurement of the cube which is 14. So it should have been;
4.25 X 14 X 17 = 1011.5
So then the box CF would be smaller as well.
4725 - 1011.5 = 3713.5
3713.5 / 1758 = 2.1123435 CF*
This was on the last calculation with the dbl front baffle and a 9" height.
