To overpowering?
Username: Rosrock2000
Mtx all da way!, Mi USA
Post Number: 149
would 425 watts be ok to send to a 250 watt sub as long as I keep the gain and bb down?
Www.15inchwangers.com
Post Number: 9494
yeah its okay. its cool to have a little head.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3536
depends on the sub and enclosure as well as if you really knwo how to use gain lol.
Post Number: 150
actually.. forget that.. i thought the thieves took my wallet to.. i just felt it in my pocket lol($125). What's a good used 10 i could get on ebay for like 80-100 bucks or so? looking for sql. ill being using sealed .66 cu. ft. sealed box. 1100d does 425 at 4 ohms... thx
Username: Drivingreckless
DD 9515f, USA
Post Number: 2687
"yeah its okay. its cool to have a little head"
lol yea chad a little "head" never hurt ne one b4
Post Number: 9498
rofl. i meant headroom. lol.
Username: Rovin
New sub : 1 ...
Post Number: 10456
ya when he said 'head' i was like wtf - his mind must be thinking about something else now ........
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1411
No.
Headroom should be no more than 10-20%.
At 250 watts, 20% more would be 300 watts.
425 watts is too much. It is 70% more power.
Remember that some people adjust the gains by matching the RCA preout voltage from the HU. If you do that, then your subs will peak prematurely and will be out of ballance with your components. Even if you try to adjust it by using the fader or subwoofer controls, you may find that you will have unsatisfactory results.
Yeah, 425 would work, and you will definetly get sound, but it aint going to be true.
Username: Nickb4247
Post Number: 56
http://cgi.ebay.com/TREO-ENGIN-10-SUBWOOFER-800-WATTS-TSX10-22-SUB-MMATS_W0QQite mZ260077279475QQihZ016QQcategoryZ3291QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
find $157 and get that. 400rms(u know it can take more).
Username: Zoomiebird
15 Wanger Premier Member, FL
Post Number: 315
lol i pushed a couple of old kicker comps with 1200rms. combined they are supposed to take no more than 400. they never gave up. lol, not saying you should, but you can.
