Ohms
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1592
I have 4 Dual 4ohm subwoofers now wired to 2ohms (2 ED NINe.1s strapped at 2ohm). If I get 4 Dual 1 ohm subs can I still wire them to 2ohm? I cant find a calculator online that shows it.
Username: Nickb4247
Post Number: 32
yes
St. Louis, MO
Post Number: 1595
Thanks man, I get really confused when strapping the amps...ED needs to work on explaining there wiring options when you strap them.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11120
http://www.the12volt.com/caraudio/woofer_configurations.asp
