Bronze Member Username: Vc23Post Number: 86 Registered: Mar-06 | I just bought a havoc and i am building a box for it... right now it is 20x30 and 10 inches deep... i need to know how to port it and what the demensions are... like do you just cut out a hole in the wood.. or what? also should you insulate the inside... im am using 3/4 mdf board as well so... |
Bronze Member Username: Vc23Post Number: 87 Registered: Mar-06 | any1? |
Bronze Member Username: Vc23Post Number: 89 Registered: Mar-06 | any1? |
Bronze Member Username: Vc23Post Number: 90 Registered: Mar-06 | yeah this is g@y... anyone? |
Silver Member Username: Dsmith07LaGrange, NC US oF A Post Number: 414 Registered: Jun-06 | wreak havoc could help you if he ever reads this, keep bumpin it up so when he gets on he can help ya |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 4657 Registered: Feb-06 | you called me g@y, now im not helpin |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 4658 Registered: Feb-06 | you called me g@y, now im not helping now. |
Bronze Member Username: Vc23Post Number: 91 Registered: Mar-06 | i said "this" is g@y not you... so throw in your 2 cents please |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2685 Registered: Nov-05 | what size Havoc.. and what can you do for MAX external dimensions |
Bronze Member Username: Vc23Post Number: 92 Registered: Mar-06 | 15' and i already built the box its 20x30 and 10 inches deep |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2686 Registered: Nov-05 | hate to say but that box is too small for a ported 15" 2.594cu.ft and that is before displacement |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 4024 Registered: Mar-04 | That box is alil small for a havoc 15". For a havoc, I would try 3.5cuft net tuned to ~35hz w/ ~50sq inches of port. Try this: 36"x16.5"x16.5" port 15" x 3.25"....24.75" long. |
Bronze Member Username: Vc23Post Number: 93 Registered: Mar-06 | yeah its in the back of a dodge caliber.... so that might not fit and i already started buildin the box so yeah im f-u-cked...... |
Gold Member Username: CenusHicksville, Ohio Post Number: 2811 Registered: Jan-05 | make the box sealed and see how you like it first. |
Bronze Member Username: Vc23Post Number: 95 Registered: Mar-06 | so would you reccomend going sealed or ported.... probably ported but oh well..... yeah since its like in a suv and all... so yeah any other suggestions feel free... i am not the most inteligent person in the world by any means.... |
Gold Member Username: CenusHicksville, Ohio Post Number: 2813 Registered: Jan-05 | for the havoc definatly ported, but i'd try the sealed box first and see how you like it, it may fit your needs as it is. |
Bronze Member Username: Vc23Post Number: 97 Registered: Mar-06 | hey wait a sec what is the cubic feet of 20x30 by 10 deep? cause i got 6000/ 144 and got 4.2? so isnt that right.... 30x20x10 equals 6,000 and 144 inches equals a square foot so ... isnt that right? correct me if i am wrong |
Gold Member Username: CenusHicksville, Ohio Post Number: 2814 Registered: Jan-05 | http://www.bcae1.com/spboxnew2.htm using that i got 2.5cf |
Bronze Member Username: Vc23Post Number: 98 Registered: Mar-06 | hmmm.. i do not know how |
Silver Member Username: Tdawg30Ohio USA Post Number: 902 Registered: Jun-06 | its cuz you arent compensating for the woods thickness..... |
Bronze Member Username: Vc23Post Number: 99 Registered: Mar-06 | ahh gotcha... throw out some numbers on how big i should make the box.... i have a dodge caliber so to fit in the back of that... also the port size and a quick diagram would be nice.... |
Gold Member Username: CenusHicksville, Ohio Post Number: 2816 Registered: Jan-05 | max dimensions would help. |
Silver Member Username: Tdawg30Ohio USA Post Number: 903 Registered: Jun-06 | have wreak havoc design u a box............he made my design and the directions were easy as he11 to follow and it sounds awesome. by the way I have a 15in diamond in a 2.5 ported tuned to 33 and it sounds great. |
Bronze Member Username: Vc23Post Number: 100 Registered: Mar-06 | i can fit like close to 40 inches across and about the same going the other way... and height doesnt matter... so yeah i got like a 40x40 area... so yeah theres your demensions...... |
