Bronze Member Username: Vash3000Post Number: 24 Registered: Nov-06 | Anyone got any amp suggestions around $300 that can power 2 JL 10W7? They are svc 3 ohms at 500 watts if anyone need the info. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3961 Registered: Dec-05 | PG xenon 600.1 from ebay or www.onlinecarstereo.com |
Gold Member Username: Alias747Eclipse Ti, MN Post Number: 1905 Registered: Apr-05 | I think that will be under powering them a bit juliob! Just save up to get a 1000/1 that definitely one of the top amps for those subs because it was MADE to power those subs. Otherwise, scour ebay for an amp that does around 1500 wrms @ 1 ohm. This is about the cheapest amp you can get that is decent and does rated power: http://cgi.ebay.com/BRAND-NEW-CLARION-DPX11500-MONO-POWER-AMPLIFIER_W0QQitemZ250 071960968QQihZ015QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 4788 Registered: Feb-06 | kikcer kx1200.1, ED NINe.1? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3963 Registered: Dec-05 | my bad... Isaac that clarion is not so good, 1050w rms at 14.4V, better try something else |
Silver Member Username: QbenjaminFlorida Post Number: 209 Registered: Nov-06 | Don't waste your money on that Clarion, we bench tested it at my buddys shop, it's terrible!!!! |
Silver Member Username: QbenjaminFlorida Post Number: 210 Registered: Nov-06 | Those are some good subs, but they are a wiring nightmare!!! Dual down to 3 ohms....? If I were you, I would jsut save up the extra $200 and get the JL 1000/1 like they have told you. |
Silver Member Username: Alexv305Tavernier, FL USA Post Number: 554 Registered: Oct-05 | The JL 1000/1s are very expensive for the power they put out, but they are very nice amps.. You could get yourself an Orion HCCA-D2400 on Ebay within your price range. 1200 RMS @ 1 ohm should be fine with good amount of headroom. - Alex |
Gold Member Username: Alias747Eclipse Ti, MN Post Number: 1911 Registered: Apr-05 | Hey Q, you mean that the CEA rating is a lie? The CEA rating on there website says that is puts out 1500 WRMS @ 2ohms 14.4v. Look for yourself: http://www.clarion.com/us/en/products/2007/audio/amplifiers/DPX11500/us-en-produ ct-pf_1165294762631.html I don't know how the CEA can get away with lying like that. |
