(Video) Dayton 7"
Username: Frkkevin
Post Number: 2678
... got bored.. heres a short vid with an old digi cam on the Dayton 7" Mid ..
http://media.putfile.com/Dayton-7-
Username: Southernrebel
Post Number: 4020
dam...thats alil beast :-)
Username: Mr_kebo
Albertville, Al USA
Post Number: 1133
wow thats impressive. Reminds me of my eu700 from eD
Username: Frkkevin
Post Number: 2679
^^.. That digi cam don't do justice.. you'd have to see them in person. For 7"s I am shocked at how low they will get.. man I want to use them in my car but if someone would buy them or take them as partial trade + money for a better set of comps I'd have to do it. I can't fit the tweets anyway. Idk.. I'd trade em for a good set of 6.5" comps as well..
Till then.. HT away! lol
Www.15inchwangers.com
Post Number: 9327
nice. it moves good.
Post Number: 9328
how much are you asking for them kev? i happen to have a little cash laying around.
Username: Frkkevin
Post Number: 2681
i really don't know man. i have no clue what they are worth. ive got two silk dome dayton tweets and those two 7" dayton mids.. they sound really good.. makes me not want to get rid of them but the only way i can get some new comps is by doing that.
ive also go two crossfire x-overs for them but one has a short on the highpass but i bet a jumper wire would fix it.. i would not charge for those cuz one is messed up.
so yeah.. i guess just make an offer. you could look them up on partsexpress but i could not find the 7" mids on there
Post Number: 9330
let me think about it then kev.
why don't you just use those?
Username: Frkkevin
Post Number: 2682
well i can't fit the tweeters... so i'd have to sell the tweeters and buy some that will fit in the stock location..
i might be able the squeeze the 7"s in but ill have to mount them to the door panel and hope i don't hafve clearance issues and leave room for excursion.
i figured it might be easier just to use some 6.5" to put in a stock location but it would be worth the effort to use these suckas :-)
Post Number: 9332
i'd just use those kev.
mount it on the outside of your door panel. cut a hole and mount it. but make it look nice.
Username: Frkkevin
Post Number: 2683
yea.. i'll have to think about it.. but if i could get a decent amount of money for this complete set.. then only have to pay like 50-60 on top of that for some a/d/s 346 or something similar.. i'd rather do that.. idk though .. well see :-)
for now they make some awesome home theater speakers
Username: Frkkevin
Post Number: 2684
... never bumps for me
Username: Frkkevin
Post Number: 2693
bumpy :-)
Username: Adddisorder
West palm, Florida
Post Number: 2807
just so you know they are 8ohm unless they are the new 4ohms that just came out. but if you use the xovers they are probly 4ohm and if you run them togather you will have very differecnt xover points due to the impeadance change
