Username: Nkknutson Post Number: 20 Registered: Dec-06
Tuesday, January 16, 2007 - 00:43 GMT If i get the ZX1000.1 and the ZX350.4 both kicker amps do i need a new alt or a new battery? thanks
Username: Jonesp Post Number: 135 Registered: Sep-05
Tuesday, January 16, 2007 - 00:50 GMT yes
Username: Basssquared Post Number: 37 Registered: Nov-06
Tuesday, January 16, 2007 - 04:43 GMT probably a new alternator because the if u get a better battery it would just cause a bigger strain for ur alternator but your setup might be fine without upgrading either you should try it as is and then if that dont work get an HO alternator
Username: Alias747 Eclipse Ti,
MN
Post Number: 1896 Registered: Apr-05
Tuesday, January 16, 2007 - 05:05 GMT What is the size of you stock alt? Because my Audi A4 has a stock 120A alt, but my old Accord had a 75 amp stock alt. That can make a big difference. But with how much power you are talking about there, it would be safest to get a larger alt to be safe.
Username: Rcorral8865 Il
Post Number: 3 Registered: Jan-07
Tuesday, January 16, 2007 - 22:16 GMT does anyone know how many amps a 2002 impala stock alternator has?
