Electrical Upgrade
Username: Mgbcs
Lincoln, Nebraska
Post Number: 84
OK...I just want to be sure I know what I am getting myself into if I purchase a powerful system. The most I would go is like 2500 RMS. So, I would need to do the Big 3, a HO alternator, new battery(s?) and 1/0 wire throughout. Am I missing anything? Also, how many amp alterator and what battery(s) would I need? Thanks!
Username: Bernymac
Cambodian
Post Number: 1767
If you can get a 240-260amp alternator that would be good. Get 1 kinetik hc2400 in the back and a smaller one in the front. do the big 3 and 1 run of 0awg from front to back will be ideal. This should run you under 1k.
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 768
Just get a 5x strap inverter system for 30,000 watts of inverter power. Then get an overpowered Class-I amp system (the one I saw puts out 8,000 w/ch x8 at 4ohms) so you could try and blow out your car speakers and subwoofers for no reason. I suspect that would destroy your alternator though.
Sorry, I must be bored.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 85
OK...so I would need a 240-260 amp? I was looking around just a little and found 205 amp, but will keep looking. Would that be sufficient ot go bigger?
Username: Bernymac
Cambodian
Post Number: 1768
look up iraggi on ebay. see if he has an alternator for you. if not, then contact him and ask for a price quote. Tell him how much power you plan to run and so forth and he'll tell you how big of an alternator you need to go.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 86
BernyMacAttack...As far as the battery goes, what would I need in the front? I know you said smaller than the HC2400, but what would you suggest? Thanks!
Username: Mgbcs
Lincoln, Nebraska
Post Number: 91
Bump
