OT - Blacklight in a car?
Username: Ars88
P.I.M.P , Pakistani/In...
Post Number: 305
has any1 ever put blacklight in a car? im about to buy 2 sticks of black neon and was wondering how it would look....any1 got any experience with it?
i don't want something dull so maybe you can gimme some brands that make really good/durable/bright light? lol
i heard of streetglow and some others but i don't know which ones to choose bcoz i nvr really seen them..
i would appreciate any suggestions
thx ^^
Username: Moey_g
SydneyAustralia
Post Number: 29
Well just so u know, the blacklight is a waste unless u got lots of white material in your car. It makes the white material look blue/purple. I had one stick in the car and did look nice.
Username: Frkkevin
Post Number: 2666
... or you could get creative with the glow in the dark paint :-)
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1901
I have black lights running along the sides of my front seats, and their light extends to where your feet are...It's actually not a bad idea, since your shoes will still glow, and cops can't as easily see them. Here I'll post some pics.
Yes, it's a little messy...I don't have a garage, so it's kinda cold in the winter to go out and wash/sweep/polish, and for the past week it's been raining lol. So sorry about the mess :-(.
Wellsburg, WV USA
Post Number: 1902
Here are some pics of my purple neons in the back seats as well...Again, sorry for mess, but I always keep the pliers with me :-).
I have mine kinda ghetto rigged, running to toggles in the glove box, and using the power/ground on the amps...I guess it's not really ghetto rigged, it's just not running to the fuse box or any other light source, but to run to the amps was MUCH easier in my case.
Username: Ars88
Post Number: 308
thanks for the pics tyler...u got power for these from ur amp?
i don't think i will be needing any of this because last nite my car was broken into and they took my whole system...bahstards also took my whole front dash peice (which means they got same car)
ima jus chill out and save up for a new car and a lil better system...
thanks a lot for the pics tho
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 415
anybody got any links where i can pick up a couple of those blacklights for cheap?
Username: Ars88
Post Number: 319
ebay?
