New member Username: FranklinmcdanielJacksonville, Florida Usa Post Number: 1 Registered: Jan-07 | I can not get my BOSE 3-2-1 SySTEM hooked up to the where the DVD part of the BOSe plays on the TV. I have audio but no pic. I do not know what I am connecting wrong either on the Dish network Box, Bose unit and /or the TV. The Tv is a 42inch Phillips Plasma. Any directions or advice will be greatly appreciated. Best regards Franklin McDaniel frankmcdaniel@comcast.net |
Silver Member Username: Arande2400dB could probably d..., SouthWest Mi... Too Many DBs... Post Number: 903 Registered: Dec-06 | I will not say my opinion on the Bose. I would assume you're using the S-video output of the Dish Box to the input of the receiver (thingy) and the component video to TV. I would think it doesn't have upconversion. Now are you having trouble with playing DVD's on the Bose itself? Are you unable to watch TV through it? It should go to the correct input on the TV from the output. You should probably hook the dish straight to the TV. |
Platinum Member Username: Project6Post Number: 12475 Registered: Dec-03 | How are the video outputs of the unit connected? |
