Set bridged gain
Username: Zoomiebird
15 Wanger Premier Member, FL
Post Number: 307
i have a 4 channel amp that im gonna bridge to 2 and get a 2ohm load. i have set my sub amp gains using a dmm, but im not sure how to set my speaker amp. the amp is rated at 70x4@4ohms or bridged 200x2@2ohms. how should i set the gains once i bridge?
Username: N2audio
Lawrence, Ks USA
Post Number: 1138
what amp do you have that's stable at 2 ohms bridged??
Assuming you want to run each bridged pair at 200w it would be
V = Sqrt(PxR)
V = Sqrt(200x2)= Sqrt(400)= 20v
