Autotek MM4000
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 747
what u all say about the mm4000 great amp? an whats the max volts u need 2 get all 4000watts an does any 1 have the messurements of it was thinkin of sellin my orion 2500 an later on in the summer buyin a autotek 4000 an i need messurments 2 c if it will fit my amp rack think its 12x27 if dat dnt work its goin in the trunk lol so ill have a custom fiberglass amp rack wit a big spot open lol
Username: 04redmach1
Columbus, GA USA
Post Number: 301
Autotek makes nice amps, but the 4000d doesn't like to be ran hard for long. If you want a good 4000-5000 watt amp that will hold together, the DD Z1 or Adessa Warlord is way to go.
Kevin
Post Number: 748
guess iam goin 2 stick wit my orion 2500 runnin 2 type rs they sound great in my car an box an if i wanna upgrade later which i might ill get another 2500 an sum re's or orion h2s or fi or sumthin
Username: Gfbl
Post Number: 14
S P D, do you have upgraded electrical? I was thinking of getting that amp but everyone says i will need to do an upgrade. I see your running two
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3861
you will need an electrical upgrade.
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 4488
^^^yes, a nice one at that.
Post Number: 756
h3ll ya ill have that 2 runs of 0/1 wire 1 power 1 ground 2 batterys 200amp alt. big 3 anything else??
Username: Juliob
Post Number: 3915
isolator
