Archive through January 06, 2007
Username: Mexicosatellite
can someone help me find the latest bin for megasat to get dishnetwork?
Username: Lklives
Post Number: 6744
286T...read the pansat 3000 thread here..
LK --
I downloaded the 286T from the website you listed on the other thread but I don't know how to download the channel list. I did a blind scan and get this message "0 transponder founded"
any advice?
Username: Jpz
MTL, QC CAnada
Post Number: 130
hi guys
Username: Aman25
Mississauga, Ontario
Post Number: 17
hi im useing a FLU and some channels disappeared can someone help
thanks
Username: Lklives
Post Number: 6747
Jacob...U can upload the channel listusing "channel master" program...or a Blind scan will work also instead of the channel list...
if U have 0 transponders then either u have a bad dish alignment, LNB, cable, switch, or receiver antenna settings
obviously the satelite signal is not getting to the receiver..best thing to do is run a cable from each sat directly to receiver then do a scan...if no channels then, its bad alignment, cable or LNB..and always reboot receiver after the scans..and make sure u have latest keys in receiver..
Username: Jchihua
how true is that fta is going down again next week that is going down because of change of bin can anybody that knows answer my question
Username: Anchu
Post Number: 25
hi LK can you please help me. i could't see any channels all i could see is technical dificulties message from dish network, is this is whats going on everyone's receiver or only mine. my autoroll is on and i am getting new keys by it self when i check the control panel. plz reply thank you . i watch suntv,Gemini tv..,
Username: Jchihua
my receiver is working fine all chanels are working
Username: Raghu
Post Number: 20
This is response to the reply provided by Nalin on Thursday, December 28, 2006 - 09:16 pm:
Nalin: Thanks for your help. You are really great. You have pinpointed the problem. The power is exactly the problem as you mentioned. I connected the cable to the old DN receiver and the PANSAT 2700a started working fine.
I have one quick questions. All our desi channels which used to come to Echo 9 is coming now in Echo 7 ( I have not yet scanned echo 9). I just did a Blind scan on Echo 7 as you always suggest. Now, do i need to do a scan on Echo 9 or not. Will the channels continue to come on Echo 7 as well?
Thanks Nalin. You helped us to start the new year with a smile :-)
Username: Raghu
Post Number: 21
Anu Singh: The problem is now resolved partly. You don't see the technical message by DN but you will see the live telecast (instead of 12 hour delay). The program is exactly as what comes in India now.
Raghu.
Username: Nydas
Post Number: 1100
On Echo 3 (61.5) yesterday, there were 2-3 Indo-Pakistani channels dwon because of "Technical difficulties" at DN. They are OK today. Sports 457 and 471 are inactive now and will probably be active around 11.00 pm eastern or even later. That is nothing abnormal.
Username: Nydas
Post Number: 1101
Raghu Raghav: I am glad you are up and running. You can do a scan on Echo 9 (121W), go into Edit Channels, sort alphbetically, and you will be able to see duplication. You can then decide to erase whole of Echo 9 or you can erase some and keep some. What I do is to get the needed channels into my favourites. I have renamed the FAV1 -FAV5 as "General", Indian, Technical, Children, and Movie. I then put the appropriate favourites into these and leave the rest in the All section, which I hardly ever bother about.
Username: Jchihua
anybody how true is that fta is going completly down again change of bins how true is that
Username: Nydas
Post Number: 1102
Raghu Raghav: If you are getting a lot of Indian channels on Echo 7 (119W), you are probably getting them from AMC 16 (118.8W). This is a new Bird since about May, 2006 and carries many of the channels that were available from Intelsat 5. They include Doordarshan, NDTV, Bengali, Marathi, etc. These are the true free channels in India and there are similar ones from other Middle East and Eastern countries. The ones that come on Echo 9 (121 W) or Echo 3 (61.5) are what in India would be called paid viewing - the big ones being the Zee and Sony networks.
The signal from 118.8W as obtained on a Linear LNB is weak, and the signal is much better with a circular LNB. Some of the latest DN dishes might be equipped with a LNB capable of both these satellites (plus the Echo 8.1 at 110W). I and many others in this forum would be very interested in finding out the LNB you have and confirmation or otherwise of my statement regarding AMC 16. You can look at the listings at
www.lyngsat*com
Username: Zaza37
Pueblo, Co Usa
new keys plz for dishnetwork
Username: Zaza37
Pueblo, Co Usa
I need keys plz plz plz plz plz.......... plz!
Username: Gennady
Redwood, CA CA
Can anybody expalin to me how to load the update direct to thr Viewsat Extreme reciever by "LOADER 2". I did connected to the PC and unzipped files but the files are not loading to the reciever?
Username: Canndy
Post Number: 42
zaza [link removed]
Username: Canndy
Post Number: 43
Gene Yakubovich: [link removed]
Username: Nydas
Post Number: 1109
There has not been a key change for DN since 28th December. There may be a change in some areas a few minutes before others.
HAPPY NEW YEAR TO EVERYBODY
Username: Luckydraw
Quebec
Post Number: 7
I would like to wish every one a Happy New Year
keep up the good work guys
Username: Viagrus
My Pansat 2500a hasnt been used for about 10 months. I have never downloaded it myself. What cable do I need and where do I hook it up (both ends). Then what do I do? I am a real newbie at this.
Username: Nydas
Post Number: 1123
Johnny Longprong:
Cable - Straight RS232 DB9 F/F avaialble at Radio Shack or similar.
for unzipping files: Winzip.exe avaialble at
http://www.totalfta.com
http://www.dssrookie.com
http://www.dssevolution.com
You may be required to join the site as a member - it is free.
Time required: Reading and downloading files - 1 hour
Uploading BIN: 30 minutes.
Suggest you get a comuter hobbyist to help you
Username: Dbsf
Saltsprinisland, B.C. CANADA
Hi guys. the last posting for B.E.V. was dec29, have there been updates since?
Username: Nydas
Post Number: 1127
Nagra2 Keys
DN - Provider ID 0101: Last Updated (Dec29 5:30pm EST)
Key 00:
84 62 90 AD 39 2A EA DB'.14 5E D0 47 57 76 2D AA(Active)
Key 01:
F5 08 EC 80 E6 EF 1E 6F'.B7 74 BF 73 69 7A AF F5
Bev '" Provider ID 0901: Last Updated (Jan02 1:00pm EST)
Key 00:
6A EC 7C 59 4D C5 8C 79'.EF 61 D0 0C 87 FF 87 3B (Active)
Key 01:
3A 99 4D B9 87 6C ED 6F'.83 34 68 6D CC DB 5E EC
Username: Itso
Renton, WA USA
Post Number: 10
Hello guys, do u have new keys for DN?
Please.
Thank you!
Username: Canndy
Post Number: 44
DN keys: Last: Dec 28 15:45
key 86: 84 62 90 AD 39 2A EA DB 14 5E D0 47 57 76 2D AA
key 96: F5 08 EC 80 E6 EF 1E 6F B7 74 BF 73 69 7A AF F5
Bev Keys: Last: Jan 2 12:50
Aux 86: 6A EC 7C 59 4D C5 8C 79 EF 61 D0 0C 87 FF 87 3B
Aux 96: 0D 68 3A 7D 4F CA 26 E2 4A DC 49 B0 25 18 91 05
[link removed]
Username: Canndy
Post Number: 45
[link removed]
Username: Hicham
Post Number: 46
thankxxx guys 4 the keys
happy new year
Username: Jpz
MTL, QC CAnada
Post Number: 131
Hi Guys,and HAPPY NEW YEAR 2007 TO ALL OF YOU.
Username: Asharfi
Post Number: 419
Guys,
Since, now we're in 2007, DssWorld will be changing its theme. From what I've heard, is that DssWorld will now support All Common and Popular receivers (Pansats, Viewsats, Fortecs, etc) Basically, now it's becoming the real DSS/Satellite website. I think that they'll shut the website near next week and they'll re-open in Feb. DssWorld Forums have completely changed and they're still working on them. So, next month, that website will provide service for all the common receivers.
Username: Lklives
Post Number: 6815
Nagra2 Keys
Dish Provider 0101: Last Updated (Dec29 5:30pm EST)
Key0: 84 62 90 AD 39 2A EA DB 14 5E D0 47 57 76 2D AA(Active)
Key1: F5 08 EC 80 E6 EF 1E 6F B7 74 BF 73 69 7A AF F5
Bev Provider 0901: Last Updated (Jan02 4:30pm EST)
Key0: 6A EC 7C 59 4D C5 8C 79 EF 61 D0 0C 87 FF 87 3B
Key1: 0D 68 3A 7D 4F CA 26 E2 4A DC 49 B0 25 18 91 05 (Active)
Username: Molari
Post Number: 13
anyone have the new updated keys for Bev?
Went down at 16:23 pm
Thanks
Username: Lklives
Post Number: 6824
dah...they just MAY be in the BEV KEYS thread!
Username: Puretrance
Montreal, Quebec Canada
Post Number: 24
Current BEV Keys
86 is active, changed Wed Jan 3 10:34:23 2007
86: C6 D6 A5 73 6D DA EB 14
AE 04 5B D5 84 01 67 36
Username: Jaz06
Post Number: 11
dish keys please.
Username: Jaz06
Post Number: 12
anybody have the new dish network keys!!!!
Username: Bertoro
Toronto, Ontario Canada
Post Number: 455
working keys...im watching tv...636 pm
Username: Lklives
Post Number: 6831
Reputable Satellite Sites..with latest KEYS, info, manuals, guides, files, bins, and LIVE chats...
Final Solution Free To Air:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
[link removed]
Username: Labatt_2000
Post Number: 8
Bev Keys as of Jan 3 at 10pm
key 00:
key 01: (active)
OD 68 3A 7D 4F CA 26 E2
ENJOY
Username: Sokol
Post Number: 16
LK, or anyone on this forum
Do you know by any chance if Globecast keys would be avilable any time soon? I am trying to open most of the Polish chanels ..Polsat, TVPolonia, TVp3 ...they are down fore more than 6 months.
Thanks in advance
Sokol
Username: Canndy
Post Number: 51
sokol try downloading the latest globecast fixes.. [link removed]
Here are globecast keys.
EB 4A C4 1A 45 5B DD 23 54 7E EF 4B 3A BF 4D 62
83 20 3C A8 E5 7B 93 A6 7B 12 67 AB 40 62 03 B1
Username: Luckydraw
Quebec
Post Number: 8
does anyone have the new bev keys,thanks in advance
Username: Brucester
Post Number: 130
cd 5b a1 99 f7 ac bc 44 4f 15 05 d6 c4 e2 75 23
Username: Jmlr
what key o or 1
Username: Brucester
Post Number: 131
01 keys for bev cd 5b a1 99 f7 ac bc 44 4f 15 05 d6 c4 e2 75 23
Username: Brucester
Post Number: 132
00 keys for bevC6 D6 A5 73 6D DA EB 14 AE 04 5B D5 84 01 67 36 have fun all
Username: Canndy
Post Number: 52
Bev Keys: Last: Jan 4 14:20
Aux 86: C6 D6 A5 73 6D DA EB 14 AE 04 5B D5 84 01 67 36
Aux 96: CD 5B A1 99 F7 AC BC 44 4F 15 05 D6 C4 E2 75 23
Username: Canndy
Post Number: 54
Key 00, 86: 84 62 90 AD 39 2A EA DB 14 5E D0 47 57 76 2D AA
Key 01, 96: 50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11
www.Livefta.com !Live Keys!
Username: Baluja
Post Number: 156
NEW DN KEYS on 1/4/2007
Key 00: 84 62 90 AD 39 2A EA DB 14 5E D0 47 57 76 2D AA
Key 01:50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11
Username: Baluja
Post Number: 157
Username: Pretty2798
Philadelphia, PA United states
Post Number: 8
thanks rakesh
Username: Azko
is it too much ask which one's active??
Username: Ftalife4
Dish Provider 0101: Last Updated (Jan 04 5:34pm EST)
Key0/86: 84 62 90 AD 39 2A EA DB 14 5E D0 47 57 76 2D AA(Active)
Key1/96: 50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11
Bev Provider 0901: Last Updated (Jan04 2:58pm EST)
Key0/86: C6 D6 A5 73 6D DA EB 14 AE 04 5B D5 84 01 67 36 (Active)
Key1/96: CD 5B A1 99 F7 AC BC 44 4F 15 05 D6 C4 E2 75 23
Username: Hoosier_daddy
Post Number: 7
Did something change I am not auto rolling anymore
Username: Canndy
Post Number: 55
Rakesh bhai, I posted the same keys 24 minutes ago.. thanks anyways.
Username: Amrit187
Post Number: 22
My dish isnt autorolling anymore either, it autorolled the keys for Nagravision 00 correctly but the ones for Nagravision 01 weren't right, whats going on ?
Username: Stargirl
help! need new pansat keys.
Username: Johnner
Miami, Florida
Post Number: 1021
Key1/96: 50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11 (Active)
Username: Canndy
Post Number: 59
Autoroll will not be working on BL bins.. some will but most will not..
check: [link removed]
Username: Gloomis2
Post Number: 7
is it down again?
Username: Canndy
Post Number: 62
no it is not
Username: Cholan
Whitby, On Canada
Post Number: 12
dish keys
Key 00: 84 62 90 AD 39 2A EA DB 14 5E D0 47 57 76 2D AA (active)
Key 01:50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11(active)
Username: Eatfish111
Post Number: 56
01 keys are the active ones.
Username: Nydas
Post Number: 1136
The question as to which key is active is somewhat unnecessary. You need to have both Keys, i.e. sixteen, two digit numbers of Key 00 and the same of Key 01, for the receriver to work.
Last time they changed the keys a few hours ago, the autoroll did not work, for many. To find a solution, is a programmer's nightmare. To get your own receiver going is simple. Turn autoroll off, put in the keys manually, make sure you save, then exit and switch off reciver for 40 seconds if necessary. Most likely your receiver will work.
Username: Prfrmnj
Post Number: 1119
This hit has only affected BL bins. VS and SV are rolling without a problem.
Last but not least (and I'm sure this has been said a few thousand time) keys are the same for all receivers. Only the active key is the one that changes, HOWEVER, as Nalin VERY CLEARLY stated, you need all Key 00 & Key 01 for your receiver to work!
Username: Canndy
Post Number: 68
NEW KEYS
86: 4B 02 88 B1 CD 63 21 D1 A8 A5 3A C8 10 58 F4 C2
[link removed]
Username: Dragunov
Keys changed again around 11pm ?
Anyone has them ?
Username: Nydas
Post Number: 1137
Keys just changed. Autoroll did not work for some receivers.
DN- Provider Id: 0101
Key 00:
4B 02 88 B1 CD 63 21 D1'..A8 A5 3A C8 10 58 F4 C2
Key 01:
50 D9 06 47 5B 8F D0 2B'..A7 ED 67 C3 10 85 1A 11
Username: Lklives
Post Number: 6854
Nagra2 Keys
Dish Provider 0101: Last Updated (Jan04 10:48pm EST)
Key0: 4B 02 88 B1 CD 63 21 D1 A8 A5 3A C8 10 58 F4 C2 (Active)
Key1: 50 D9 06 47 5B 8F D0 2B A7 ED 67 C3 10 85 1A 11
Bev Provider 0901: Last Updated (Jan04 05:41pm EST)
Key0: C6 D6 A5 73 6D DA EB 14 AE 04 5B D5 84 01 67 36 (Active)
Key1: CD 5B A1 99 F7 AC BC 44 4F 15 05 D6 C4 E2 75 23
Username: Hanz
Post Number: 157
LK my man, always glad to see you on here. Did you have a happy new year? What did Santa get your kids for Christmas this year? How is the weather lately for this time of year, over where you reside?
Username: Asharfi
Post Number: 423
Guys,
There you go! We finally finished working on DssWorld. Now they support the following receivers:
Fortec STAR Lifetime Ultra
Fortec STAR Lifetime Classic NA
Fortec STAR Mercury 2
Pansat 1500
Pansat 2300
Pansat 2500
Pansat 2700
Pansat 2800
Pansat 3500
Pansat 5000
Pansat 6000
ExtremeView Magnun XV 3300
SkyView RX 600
Viewsat Platinum
Viewsat Xtreme
Viewsat Ultra
Viewsat PVR7000
C00LSAT 4000
C00LSAT 5000
C00LSAT 6000
Right now, they have some receiver's tutorials and more Gudes and How-to stuff will be there soon. All the latest bins for the above receivers are there. Plus, they got some cool features like PPV Movies info, Sports Info, etc.
The superb thing on there is the Internationl Forums. Yes, they got forums for the following languages, too: French, Spanish, Greek, German, and Former YU Republics. Transponder news and updates will be posted there. They also have section for Other Receivers. They don't have files in there, but you can post links there. Yes, links are ALLOWED. I know this is kind of strange because most of the Dss webistes don't allow links, but DssWorld does. The website rules are simple. They have General Discussion forum where you post stuff like you're posting here at www.ecoustis.com. They have some info on satellite hardware, etc. So, register for free and be the part of DssWorld Community. The registration will take only 1-2 minutes. And, above all of this...There server is faster than other Dss websites - This is proved by Web Server Speed Checker, that's what I've heard, but yes, the server is faster in my opinion. Live Chat is almost ready and will be there, sooooon. Enjoy, friends! Everything is secured, that's why they don't allow files for guests, ONLY registered members are allowed.
Username: Fcmiller
It would appear the keys are changed?
Username: Fcmiller
It would apprear that I am wrong some how one key rolled unexplainably? I am ok now.
Username: Nydas
Post Number: 1139
Fred Miller: It is called Key morphing, a technique charlie uses to stop you from watching.
IF IT BECOMES troublesome,
1. set auto roll off,
2. do set default keys
3. manully input Key 00, and Key 01 and save
4. turn receiver off and then turnit on after 30 seconds.
Username: Mc_sunny
Post Number: 954
Bev New Keys: 01/05/07
key0: CAED038E0607D92AB0E631EB2217BFD6 <-Active
Key1: CD5BA199F7ACBC444F1505D6C4E27523
Username: Sokol
Post Number: 17
LiveFTA.com,
Sorry for late reply, I looked for the fix on the link that you provided but I could not fine the fix for Pansat 2700 which I am using at the moment.
I would be grateful if you can provide some assistance or link.
Thanks again,
Sokol
Username: Keymaster
Post Number: 51
hi, can any1 please tell me how to put files into my cools*t 5000? I have the wire but I don't know what to do next. some1 please help me
Username: Asharfi
Post Number: 431
Guys,
If you need a uploader for your Pansat receiver(s), download Blacklist Uplaoder 1.4. Yes, this uploader will work for all Pansat receivers (Pansat 2700, 1500, 2500, 2300, 2800, 3500, 5000, 6000). Get it from www.dssworld.co.nr - Original files for from Blacklist and other receiver's coders!
Username: Canndy
Post Number: 73
Bev Keys: Last: Jan 5 14:20
Key 00, 86: CA ED 03 8E 06 07 D9 2A B0 E6 31 EB 22 17 BF D6
Key 01, 96: CD 5B A1 99 F7 AC BC 44 4F 15 05 D6 C4 E2 75 23
KEY 00
00: CA ED 03 8E 06 07 D9 2A
01: B0 E6 31 EB 22 17 BF D6
KEY 01
00: CD 5B A1 99 F7 AC BC 44
01: 4F 15 05 D6 C4 E2 75 23
Sokol please check the Pansat files, [link removed]
Username: Ricandlisa
ok can someone tell me wich keys are active
on the bev keys can someone help me . is o8 and o9 the same thing as 86 and 96
Username: Freeload
Post Number: 21
help need autoroll for c00lsat
Username: Cholan
Whitby, On Canada
Post Number: 13
new keys please
Username: Canndy
Post Number: 78
Those are the keys, latest keys is always active..
[link removed]
Username: Holiday
Please, help!
How do I turn off the autoroll?
Thanks in advance,
Username: Lkirkland
Maryville, Tn Usa
Post Number: 19
hey help
i have nim sat now but don't know how to load bev keys will some one please tell me how know how to load dn keys
Username: Hanz
Post Number: 162
juliette, you go to menu, go to installation, and you'll have some options there including autoroll which you can choose to turn on and off.
Username: Hrrysoni
Chicago, IL U.S.A
Post Number: 13
Hey everyone, I entered the new keys 4 pansat3500 n all channels r coming xcept 4 zeetv, zcine n B4U....whnevr i do go on these channels a pop-up windows says "positioner setting"....wat shud i change in the pos. settings n 2 wat in order 4 these channels 2 work?
......Thanks in advance
Username: Picass0
Post Number: 16
Is it possible it went down again I enterd this keys and it still dont work ?
KEY 00
KEY 01
Username: Vedjourian
Post Number: 24
Hi Quick question. I upgraded a fortec lifetime ultra to the 286t bin file, and now i cannot find where to enter the keys. Can someone please help me. The whole interface and background seems to have changed.
Username: Procomp24
Confirmed, key
is working good on my pansat 2500a
Username: Nydas
Post Number: 1141
DN - Provider ID 0101: Last Updated (4th Jan, 2007)
Key 00:
Key 01:
BEV - Provider ID 0901: Last Updated (5th Jan., 2007)
KEY 00
CA ED 03 8E 06 07 D9 2A'.B0 E6 31 EB 22 17 BF D6
KEY 01
CD 5B A1 99 F7 AC BC 44'.4F 15 05 D6 C4 E2 75 23
Username: Nydas
Post Number: 1142
Alain: The keys you entered are for BEV and the provider ID should be 0901. If you intend to do DN then the keys have been posted above for DN.
Username: Nydas
Post Number: 1143
Armenian-Prince: Menu/parental control
enter 0000 in 2nd PIN.
Autoroll control is at the bottom.
Nagravision 2 is where you enter the keys.
Username: Canndy
Post Number: 83
Always new keys: [link removed]
Username: Picass0
Post Number: 17
Nalin Nyda : thankyou it's works now it was almost midnight when I tried to fix the keys I was a bit tierd of my days thank you again :-)
Username: Fadil
Post Number: 21
hey guys. Can anyone tell me why im gettin BEV channels if i enter DN keys?? i just moved a while ago and i always watched DN and now i get BEV channels. Thanks
Username: Lklives
Post Number: 6888
Fadil...
Can ONLY be 2 reasons..NO OTHERS!!!!!...LMAO
1..your dish is aimed at 82-91W Bev satellites
2..U have autoroll on, and its catching the Bev keys
