Looking for a single 10"
Username: Pike110
12w6v2s, Indianapolis...
Post Number: 344
I'm looking for a 10" sub that I will most likely put in a sealed enclosure. I listen to rock music, so it needs to be able to keep up with the double kick drums etc... I will be running it with a nine.1 so it can get anywhere from 1200 to 400 watts. Any suggestions would be great. I didn't really want to spend more than a couple hundred.
Username: 04redmach1
Columbus, GA USA
Post Number: 316
SI BM 10. DD 2510.
Kevin
Username: Pike110
Post Number: 345
I was looking at the si's, but it didn't seem that I could get one under 250. Do you know where I can pick one up?
