How to change the key on Dish 301.013 converted to Pansat
Username: Van1
Post Number: 16
thanks
Username: Ke5aqn
Shawnee, OK USA
Post Number: 186
how hard was doing that conversion?
Username: Cronnic
Post Number: 68
You need a card programer for that!
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 673
And how well does it work?It can't work as good as a pansat,let alone better,so why go to the trouble to do that?
Username: Lklives
Post Number: 6925
I have heard that since they keys changed their is no way to input new keys after doing this plastic to FTA conversion..thats what plastic users and people who have done this conversion are saying..
Post Number: 681
LMAO.And probally no way to convert back to a 301.13...lol
Username: Juancho
Superior Lake, Nothwestern ... Canada
Post Number: 312
I read that a card programer is need it to change the keys on a 301 converted a 2500 .
Username: Juancho
Post Number: 313
Changing keys to a vidmoded 301-013 to pansat2500a. this came from other site. I don't take credit. just trying to help.
1) Press menu.................
2) select parental control..........
3) scroll down to second pin.........
4) press 0000........
4a) select autoroll an turn off all of them off. (repeat fro1 to 4 step. ....
5) new screen should pop up select set defaul and wait 10 seconds.............
6)select niagra2.................
7) use right arrow key to scroll to 0101,,,,
8)change 0101 to 7101 and press ok........
9) press the right arrow key once.you will see 0901....................................
10) press the right arrow key again.you will see C001.............................
11) change C to 0..........................
12 press the down key once and you will see 00
13) enter the first set of active key code in (00
13a) for letters use PAGE button UP or DOWN to change letters.......................
14) press select twice and make sure the OK button on the right of the TV screen flash.then wait 10 seconds..................
15) press the UP key once..............
16)use the right or left key to change the 00 to 01.......................................
17) use the down arrow key and input the second set of key.....................
18)press select twice..etc.
19) press CANCEL key untill you get the screen....and watch TV>......
Username: Van1
Post Number: 17
Wow! what the sequence! Where did you find that?
Thanks
Post Number: 686
Kinda like converting a bycycle to a pickup truck.
Username: Lklives
Post Number: 6960
Thats the same procedures for ANY FTA by pansat or pansat clone...its just giving U the Bev (0901) DN (0101) and globcast (C001) options to choose from..but good effort Juan...yes I have seen that too, but hear its not working on these converted 301's..I dunno, I didn't try this..
Username: Juancho
Post Number: 316
I though the same when I read the procedures.the only thing that changes is the remote keys. I din't have one too, anyway,someone should try
Username: Daneegha
Post Number: 37
I personally did convert one and I still can't get it to work, it is a time consuming and for the comments that I'v seen, "is not worth it".
After you get it up and running you will only get sat 110 channels and not all of them from what I know. Also you cannot use any switches for multi-satellite. My sugestion is sitck up with regular fta recievers. Your time is more valuable than what this convertion is worth.
Username: Lklives
Post Number: 7024
I just recently spoke to a few who did this conversion, and they all say now that they love it, confirmed it works great, and receives all the same 110 and 119 channels...and the manual input of keys is working well and in the EXACT same manner as U would input them into the Pansat 2500...no plastic card or programmer is used when inputting keys!
Username: Daneegha
Post Number: 38
After I adjust a few settings I finally had my 301.013 up and running. Thanks to all of you guys for your support. This is really GREAT...
Username: Daneegha
Post Number: 39
The conversion is really simple if you follow the correct procedures. I say this beacause there is some people that is giving the wrong info and this makes something simple into a very complicated challenge. After all, this becomes to be a very simple conversion and You will be satisfied to see your old and dusty reciever back to life again...
Username: Daneegha
Post Number: 40
Oh, By the way the procedures juanramirezo posted are the correct ones. this is after you vidmod and flash the reciever.
Username: Juancho
Superior Lake, Northwestern... Canada
Post Number: 356
da-neegha. remember ,its now a pansat2500, don't use Sw21, or Dishpro 500 LNB's. Legacy LNB's in conjuction with a DiSEqC scan more channales than legacy twins LMB's
