Dd 3512
Username: Hockeyknight
Post Number: 595
i got a dd 3512 and i wanna know how to amp it........im thinking a kicker kx 1200.1 or a zx 1500.1.....dose anyone know the birthsheets of these and also do you think i could run them at 2ohms of a 140a alt and a red top?????
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 735
the 1200.1 does like 1428 and the 1500.1 does like 1750 something like that and the 1200.1 would be better for that alt
Post Number: 596
how about a 200a alt and a red top
Username: Southernrebel
Post Number: 4017
if that sub is dvc 4ohm....get the ZX1500.1 or 1000.1
Post Number: 597
it is
Post Number: 598
could i run that 1500.1 off a 140a alt and a red top???if not could i run it off a 200a alt and a stock batt??? also anyone know where i can get some cheap 0 gage?? thanks
Username: Adddisorder
West palm, Florida
Post Number: 2760
run it on a 200a alt with a zx1500.1 for wire knukonceptz.com get the KLM
Post Number: 599
whats the klm i cant find it.......but i will be fine with a stock batt and a 200a alt????? ill probly get a red top later but i wont have the $$$ for a wile
Post Number: 600
jk found the klm
West palm, Florida
Post Number: 2767
if your stock battery is in good condition and you dont draw heavy load off of it then youll be ok for a while but you will need to upgrade it
Post Number: 601
what kind of voltage should i expect to see with the zx1500.1 and a 250a alt and no batterie
