Is it possible to hook up 2 digital receivers to TV and VCR?
Username: Hanz
Post Number: 163
I'm looking through my Pansat 2500 manual and I was wondering if it was possible to connect my Pansat 2500 digital receiver to my rogers canadian digital receiver to my TV and VCR.
A simple yes or no would suffice from those who understand my question:-)
If it's possible, then I'll do it myself tonight.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 192
yes
if you need more info just ask
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 729
And very simple to do.
Username: Rogybe
Post Number: 18
If your TV has only one coax hookup you can only connect one receiver to TV, but you also can connect from one receiver output to another receiver antenna in, in that case the one receiver need to be off, to get the picture on TV from the other one. Some receivers have TV Video switching capability where the receiver don't need to be off but for some people that may be confusing. But if you have better TV that has video inputs or two coax connections than you can do it that way to.
